Getting an alignment... some questions.
Old Mar 17, 2003 | 09:36 PM
Downey's Avatar
Default Getting an alignment... some questions.
my car has some terrible wear on the passenger side so its time to get an alignment. my car is lowered with Tein HA coilovers (about 2"). my question is..
what should i set my toe to? people say 1/8" toe out helps the car to rotate.. true?
i dont have a camber kit, so my negative camber will stay the same, but how much should i set my front and rear toe? in or out?
Old Mar 17, 2003 | 09:54 PM
TREVER's Avatar
Default Re: Getting an alignment... some questions. (Downey)
If your cars lowered and you have no camber adjustibility, You need to set your toe in. Front 4mm rear 3mm. I have had good tire wear with these settings.
Old Mar 17, 2003 | 10:01 PM
Downey's Avatar
Default Re: Getting an alignment... some questions. (TREVER)
so toe in works good for tire life? i dont really care to much about to tire life.. i mean i dont want to be replacing tires every oil change.. but id like the car to handel good.
Old Mar 17, 2003 | 10:09 PM
TREVER's Avatar
I f your a cheap *** (like me) and can't adjust camber. Toe in will sastisfy your handling and tire wear needs.
Coopa B18c5
Jan 18, 2013 07:58 PM
VTECROAR96typeR
Suspension & Brakes
Apr 4, 2010 10:11 AM
zccr-xsi
Suspension & Brakes
Apr 10, 2006 06:42 PM
wreckedmyteg
Oct 5, 2005 07:50 PM
4DRPIMPIN
Suspension & Brakes
28
Feb 24, 2005 09:11 AM
