Simple Clutch Slave Cylinder Question
Old Mar 17, 2003 | 08:53 PM
intekragsr's Avatar
Default Simple Clutch Slave Cylinder Question
On my slave cylinder, the lottle expanding boot thing is torn. I was told it was fine but I really dont think so. Is it ok if there is a little tear in it or is it supposed to be air tight?
I was trying to get pressure in my clutch pedal but i couldnt. I tried bleeding and all that stuff but it just wouldnt get pressure. I just need to know if it is because of the slave cylinder boot.
Thank you
Old Mar 17, 2003 | 09:00 PM
Pengo's Avatar
Default Re: Simple Clutch Slave Cylinder Question (intekragsr)
the boot just sits over that little piston. it should only be there to keep it clean and keep foreign particles out. no need to be air tight.
if your clutch pedal is on the ground and you can't get pressure back, i'm betting you need either a new slave or master, or possibly both, but hopefully not. i'd go with slave first. did it look like there were dirty particles in the brake fluid when you bled?
Old Mar 17, 2003 | 09:04 PM
tilt's Avatar
Default Re: Simple Clutch Slave Cylinder Question (Pengo)
Old Mar 17, 2003 | 11:36 PM
intekragsr's Avatar
Default Re: Simple Clutch Slave Cylinder Question (tilt)
nope they are not leaking. Maybe I am bleeding it wrong? Can someone give me some pointers?
I am basically hooking a tube to the drain hole, and tube submerged ,and pumping like there is no tommroow and it is not doing anything What am i doing wrong or am i skipping a step?
Old Mar 18, 2003 | 06:38 AM
Pengo's Avatar
ok, this is what you need to do if it is just bled incorrectly:
1. grab a friend who is willing to sit there and pump the clutch on command.
2. tube to nipple on slave. containter (clear is better) filled with a lil bit of brake fluid. end of tube submerged in fluid.
3. have friend pump pedal a couple of times while nipple is still closed and hold down the clutch. he should not let go.
4. use wrench to loosen nut on nipple and watch all the pretty air bubbles come out.
5. close nipple when bubbles stop coming out. now friend can let go of pedal
6. repeat 3 thru 5 until there are no more bubbles at all
hitop
Aug 13, 2015 10:34 AM
Dool_Ohver_Hed_Cam
Jul 3, 2007 06:01 PM
vlc92189
Nov 6, 2006 08:49 AM
freshvibes
Mar 10, 2006 05:43 AM
intekragsr
Mar 18, 2003 01:15 AM
