Camber Problem......Need Help!!!
Old Mar 17, 2003 | 08:16 PM
DSeriesBeeKilla's Avatar
Default Camber Problem......Need Help!!!
OK here's the problem...I have a '99 Coupe with Neuspeed Race Springs with camber kit all the way around and even after a 4 wheel alignment my rear wheels are still cambered....the rear wheels are tucked and they are lined up as far as they can without rubbing the fender....the question is what can I do to be able to straighten them up some more? Roll the fenders? How do I roll the fenders? How far can a fender be rolled without lookin' like shizah? Thanks in advance.......
Old Mar 18, 2003 | 07:23 AM
Default Re: Camber Problem......Need Help!!! (99D16VTECCivic)
ttt
Old Mar 18, 2003 | 07:59 AM
noNOS4me's Avatar
get it re alligned....just my .02
Old Mar 18, 2003 | 08:02 AM
B16A2-EM1's Avatar
Default Re: Camber Problem......Need Help!!! (noNOS4me)
If your camber kit is adjustable, adjust it till it fits, or ride higher or get fenders rolled. Some body shops do it, they have a machine and if the paint cracks they touch it up for ya.
Old Mar 18, 2003 | 08:03 AM
HENRY's Avatar
New User
Leave it as is unless you want to roll the rear fender lips. And if you do decide to go that route, don't try the baseball bat method. Get a shop to roll or trim it off then you can further adjust your rear camber. But as I said, I would just leave it and rotate tires more often.
Old Mar 18, 2003 | 04:27 PM
Default Re: Camber Problem......Need Help!!! (HENRY)
does anyone know if there is any way i can purchase a short rear lower control arm to pull the bottom of the wheel closer to the car instead of pushing the top out...the top can't go out anymore b/c it is tucked and it will hit the rear fender....i think if i can get a shorter rear lower control arm it may solve my problem....thanks in advance....
Old Mar 18, 2003 | 04:30 PM
like i said the rear can't be stood up straight anymore b/c it is tucked and it has already been aligned...it's not the alignment that is off it's the camber.....
Old Mar 18, 2003 | 04:32 PM
Default Re: Camber Problem......Need Help!!! (B16A2-EM1)
and the camber kit is adjustable....
Old Mar 18, 2003 | 04:34 PM
Happyman's Avatar
So adjust it. Or get your money back and use the washer trick.
Old Mar 18, 2003 | 04:36 PM
tonyxcom's Avatar
There is a company that makes shorter rear LCA's, but I cant think of the name right now.
I have -1.5 degrees of rear camber and I love it.
Camber is your friend. Learn it, love it.
Old Mar 18, 2003 | 07:34 PM
Default Re: Camber Problem......Need Help!!! (Happyman)
there is nothin' wrong with the camber kit...my wheels are tuckin' in the back....that's why i can't fix the camber on them and that's why i am wonderin' if someone makes a adjustable lower control arm so i don't have to roll my fenders or raise my car up
Default Re: Camber Problem......Need Help!!! (tonyXcom)
well dude if you ever figure out what the name of that company is...let me know....
Old Mar 20, 2003 | 06:56 PM
ttt
Shakey021
Jun 7, 2010 07:47 AM
taquatch.
Suspension & Brakes
Feb 4, 2009 11:39 AM
corkss
Suspension & Brakes
Dec 2, 2008 11:30 AM
bimmeris
Jul 14, 2008 10:28 PM
warwagon
Jun 2, 2006 09:42 AM
