after seaching, i still can't find the proper info for H22 EG
Old Mar 17, 2003 | 07:20 PM
Boostless97Lude
Guest
Posts: n/a
Default after seaching, i still can't find the proper info for H22 EG
i want to do an H22 swap, i know all the parts i need, but other than that, i cna't seem to find much very good info..... i am looking for maybe a write up or something about the process of the swap..... the quirks of it, that hard parts, some tips, etc.... anyone have any ideas?
Old Mar 17, 2003 | 07:25 PM
andrew dc's Avatar
Default Re: after seaching, i still can't find the proper info for H22 EG (EX-Boosted97Lude)
would this help?
http://www.hasport.com/Tech/Installs...0Civic%20H.htm
Old Mar 17, 2003 | 07:27 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: after seaching, i still can't find the proper info for H22 EG (CRX25)
not really...... thanks anyways, the main think i am looking for is
A: is it true that some cutting and welding on the chasis is required
B: what's the best way to run the shifter cables
Old Mar 17, 2003 | 07:34 PM
JdmCIVIC853's Avatar
http://www.h22hybrid.20m.com
Old Mar 17, 2003 | 07:50 PM
Downey's Avatar
a. yes, using the HCP mount kit, u have to notch the passenger side tranny mount so the cable shifters can operate correctly. no welding is required.
b. run the cables under the car near the exhaust, then cut a hold right under the cup holders and run the inside the car, then cut another hold for the prelude shifter box.
Old Mar 17, 2003 | 07:54 PM
poison's Avatar
For HASport mounts, you will need to cut off the tranny mount. HASport uses it's own mount to mount the H22 into the engine bay. The reason for cutting off the tranny mount is for best clearance of the shifter/gear selectors on the tranny.
HCP, you will need to trim it. Otherwise, no 5th gear or reverse.
Best way to run the shifter cables is to dremel out a 2x3 in hole about 2" in front of the cup holders. Best way to align it is to have the cables on the tranny, once the engine is mounted, pull the cable shifters so they aren't hanging/dangling around, and you will be able to align the hole to feed the cables to the shifter assembly.
HTH.
Old Mar 25, 2003 | 06:45 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: after seaching, i still can't find the proper info for H22 EG (poison)
wel, i am actually putting one in a del Sol, so, and other measuring points to use for the place for tha cables to go through??
any of you guys stil have AC or PS?? i know someone makes that bracket for the AC condensor... http://www.jdmshit.com has them, but can i use that bracket with the HASport mounts???
Old Mar 25, 2003 | 06:52 PM
poison's Avatar
Yup, the mounts with the HCP a/c bracket will work. You might have to do some fabrication on the PS, and using a 97+ prelude PS line. (which you can use from your car)
For aligning the cables, the proper way of doing it is to put in the motor, install the cables, and pull the cables to where they do not wiggle/dangle around to hit the exhaust, and drill the hole where the original mounting goes.
HTH
Old Mar 25, 2003 | 07:00 PM
Boostless97Lude
Guest
Posts: n/a
how long did it take you to do your swap? i have done my share of B series swaps in EGs and Tegs, and have pulled the H22 out of my Lude and put it in before, so that work shouldn't be much of a problem, just wondering about time mostly
Old Mar 25, 2003 | 07:10 PM
poison's Avatar
took my friends and myself 2 days. not hard at all. you know about the rear mount several times i'm sure
Old Mar 25, 2003 | 07:11 PM
Boostless97Lude
Guest
Posts: n/a
Old Mar 25, 2003 | 07:13 PM
poison's Avatar
LOL, I knew you did.
I hope you can move your arm around in 80 ways, because that's what you're gonna have to do
Old Mar 25, 2003 | 07:17 PM
Boostless97Lude
Guest
Posts: n/a
man, i been practicing, i'm up to 108 ways so far
Old Mar 25, 2003 | 07:23 PM
poison's Avatar
damn, either you wack a lot, or you broke it several times
j/k
Old Mar 25, 2003 | 07:26 PM
Boostless97Lude
Guest
Posts: n/a
j/k
nah, i since i am technically the "mechanic" of my gang (working on my ASE cerification), i always get the bitch work like putting in the rear mount, and pulling axels, and all the hard ****, b/c "but you know what your doing"....
Old Mar 25, 2003 | 07:31 PM
poison's Avatar
LOL, trained the hard way. That works
You probably have the rear mount down to 2 hours
Lsweez
Oct 18, 2007 07:36 PM
EGhatch22
Dec 8, 2004 03:17 PM
Hondasaurs
Mar 7, 2003 08:02 PM
loclowd
Aug 19, 2002 11:42 AM
