what size tires for 16" wheels
get 215/40/16
dont get 205's i use to run 205's and now i'll runing 215
you will be a lot happyer with 215's
[Modified by riceball777, 7:58 AM 3/18/2003]
I looking at getting some Kumho Escta Supra 712s, 205/45/16s for the new wheels i'm getting.
Not cheap! I didn't expect new tires in this size to cost that much more, Tirerack has a pretty good deal $352 shipped for a set of 4 to where I live.
here's a neat little app that'll show you what tire sizes you can use if you get larger wheels to keep your ratio basically the same:
http://www.miata.net/garage/tirecalc.html
Definitely 205/45/16 will retain the stock diameter.
Here are some pics.
This is itr206's car from
https://honda-tech.com/zerothread?id=414639
Here is mine:
Here are some pics.
Here is mine:
215-45-16, the 205-45-16 is = to stock diameter, but that's too small when you consider most of us are putting down more power. Go for the 215-45-16, a heck-uva lot wider and you can get the falken azenis for a decent price.
I've run the 205 and 215, the 215 will absolutely protect the rim better as well. Looks fabo too!
205/45/16 -
215/45/16
Yoko are jokes, get the azenis. Trust me, the falken is what drove my STS teg to 1st place national win.....http://www.tegsportracing.com/solora...com/pgoss.html
215/45/16
to vwong:
http://www.scca.org/amateur/solo2/pr...g/results.html
http://www.scca.org/amateur/solo2/na...r/results.html
Check out the results for yourself. Car was only at 2 prosolo events and pulled a 1st & 2nd. The 2nd event was part of the national tour. Wanted to participate more in 2002 series, however car was hit by a drunk driver and in the shop for 2 mths.
All I was trying to say to the original person posting, is the azenis is a winning choice, as is the 215-45-16 size. That's it.
[Modified by stegs, 3:00 PM 3/18/2003]
Thanks
Aaron
to vwong:
I have a 94 RS with stock suspension (except ITR rear swaybar) and 16 inch rota slipstreams with +40mm offset. I am currently running the 205/45/16 kumho 712's and was wondering if the 215/45 azenis would fit under my car with the +40mm offset? What about if I lower the car 1.5 inches?
Thanks
Aaron
My 215/45/16 clear the fenders easy and I am lowered like 2.5 and 2, this is with my volk TE37 16x7's I forget the offset thou, sorry. It might be the same.
Pat
Thanks
Aaron
Pat
Pat
Pat
