some light on my dash is goin off and i dont know what it means
a light that says maint rego or something like that keeps blinking. what does it mean and should i get it checked? thanks
just a light that comes on every 7500 miles. basically reminding you of things on your service schedule. just keep up to date on your maintenance and you can ignore the light. the resest button is at the bottom of the dash. just hold it down until the light goes off
Taken from TI
This indicator reminds you that it is time to take your car in for scheduled maintenance.
For the first 6,000 miles (9,600 km) after the Maintenance Required Indicator is reset, it will come on for 2 seconds when you turn the ignition switch ON (II).
Between 6,000 miles (9,600 km) and 7,500 miles (12,000 km) this indicator will light for 2 seconds when you first turn the ignition switch ON (II), and then flash for ten seconds.
If you exceed 7,500 miles (12,000 km) without having the scheduled maintenance performed, this indicator will remain on as a constant reminder.
[Modified by sys3rror, 10:42 PM 3/17/2003]
ok if i need "scedualed matenance" what does that mean? if i change my oil regularly and keep an eye on my fluids then do i need to really take it in?
