92-95 temp gauge swap with tach?
Old Mar 17, 2003 | 01:00 PM
civicmatt's Avatar
Default 92-95 temp gauge swap with tach?
On a 95 civic cluster, can you just take off the temp gauge and swap in a tach? Or do you need to swap the whole cluster? I would like to get a more accurate temp gauge anyway. Thanks.
Old Mar 17, 2003 | 01:16 PM
MilanoRex's Avatar
Default Re: 92-95 temp gauge swap with tach? (civicmatt)
You need to swap out the whole cluster.
Old Mar 17, 2003 | 01:20 PM
civicmatt's Avatar
Default Re: 92-95 temp gauge swap with tach? (MilanoRex)
why? Is it wiring or mounting? Thanks
Old Mar 17, 2003 | 09:43 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Because if you have any model in 92-95 that is not EX/SI/LX/VX then the gauges are setup differently. The models listed above are setup like this: tach/speedometer/fuel&temp, while those not listed are: temp/speedometer/fuel. There is no tachometer on those not listed so both sides opposite the speedometer are near the same size in diameter as the speedometer, while the models listed above have fuel and temp sharing a much smaller diameter then both the speedometer and the tachometer. Too tired to really get into it sorry. . .
Old Mar 17, 2003 | 09:48 PM
GTlvr82's Avatar
Just go to a junk yard near you and get a cluster with the **** you need and near the mile or higher than your car. they run pretty cheap.
Old Mar 18, 2003 | 09:49 AM
civicmatt's Avatar
Default Re: 92-95 temp gauge swap with tach? (GTlvr82)
thank you.
t_can
Jul 27, 2016 07:06 PM
eg6sir88
Nov 20, 2006 11:10 AM
eg6sir88
Eyal 951
Oct 26, 2006 06:02 PM
