Ingalls front camber kit Question???
I installed my front camber kit and got my car aligned but i notice a noise coming from the driver side front, could the camber kit had come loose or something...its a single knocking noise when turning the wheel to the left..has anyone else run into any problems like this????please let me know...thanks
Well you got the car Aligned and the nuts were LOCKED down once they tuned it correct ?
i know the different bushing types give diff noise ... I got the Rubber Bushing Ingalls ... no noise here ...
check the Tires.. now that the will has the camber corrected ... maybe the tire is rubbing on something ? are you riding on a crucial drop ? could be lots of noisey things (:
I have the rubber bushings as well....is there anything you have to do with those bushings...the drop is pretty low but not that low....thanks for the help though...anyone else???
I have the rubber ones with no noise ...nothing special you have to do with them being rubber .... but if that bottom nut isnt locked down ... the camber alignment could move while driving ... does your camber still look good since the alignment ? or does it look like it might have slid back to negative a some ?
it kinda looks like it moved back...I'll have to check it...thanks for the help
get a reciept too .. that way if the Tools STILL forget you can take it right back after a day of driving
yea i already took it back to those idiots and they didn't do crap so Im gonna take it to another place and have them check it out
