Instrument Cluster 92 SI
My speedo is going bad in my instrument cluster. I thought it was the VSS but replaced that and still does it. What other clusers will plug and play in my 92 Si hatch? TIA
But the plug wires and ends are all plug and play? Like if I got a 99 si cluster it will bolt in and my plugs will plug right in?
K how about this. What speedo will plug in? Any or must that be from a 92-95 civic? MY speedo is the only thing that decideds to work now and then. I replaced the VSS and still same problem. WHen I hook up my aem I can always read the speed. So that tells me the speedo is going bad. Thanks
yeah I am just looking for a plug and play to fix the problem. So if I get a speedo out of any civic from 92-95 that should work? I have a 92 si.Thanks for the info.
