Tie rod or wheel bearing..
Old Mar 17, 2003 | 10:04 AM
Outsane's Avatar
Default Tie rod or wheel bearing..
I just swapped si axles and hubs on my new CRX..
some how HF axles, hubs and brakes ended up on a si..and I needed to replace a very bad axle, and I had SI axles and I could pick hubs off a part out car, so I went all the way..
Now I have a bad shudder, on my pass side during braking, and it clunks over bumps in the road. Braking is horrible.
the Tie rod has a little play, but it wasn't a problem before.
When I shake the wheel it moves a bit back and forth..
How can I diagnose whether ot not its the Wheel bearing or tie rod?
thanks in advance.
Old Mar 17, 2003 | 10:17 AM
ElementMotor's Avatar
Default Re: Tie rod or wheel bearing.. (Outsane)
My crx does the same thing and my tie rods are good, I've been told its my steering rack, so thats what I'm doing next.....
Old Mar 17, 2003 | 10:22 AM
Outsane's Avatar
Default Re: Tie rod or wheel bearing.. (EF8 ownz u)
Would be more inclined to say it was my steering rack if it did this before I swapped axles, and hubs.. I didn't touch the Steering rack..
But its only after I swapped everything that this happened..
Old Mar 17, 2003 | 11:02 AM
DJ_SaNdOz's Avatar
tie rodis my guess. i have replaced all 4 hub assemblies w/ in the last 6months & i replaced the passenger side tie rod, now the sound is back-it has to be the driver side tie rod- i knew I shhopuldn't of half assed it-oh well.
Old Mar 17, 2003 | 05:54 PM
Toptul_Honda's Avatar
New User
Default Re: Tie rod or wheel bearing.. (dj_sandoz)
i had the problem of my car rattling. replaced all balljoints (upper lower and tie rod) and no more rattle
Old Mar 17, 2003 | 06:59 PM
gray89si's Avatar
Does your steering wheel not quite straight when youre driving down the road in a straight line and does it feel like theres some play when you switch lanes?
Old Mar 18, 2003 | 10:58 AM
GlowingRotorsXSI's Avatar
Default Re: Tie rod or wheel bearing.. (gray89si)
it's the hub man. my hatch did the same thing. you could grab the wheel and move it back and fourth and you could kick it and it would make like a " clink" noise. try the hub bearing. i had a dx hatch and i put a spindle off a 91 Si hatch on there and it cleared the problem right up. good luck!
Old Mar 18, 2003 | 05:46 PM
CRXGSR's Avatar
Default Re: Tie rod or wheel bearing.. (ShoeBoxRacer90)
Here's what you do. Jack up that side of the car. Shake the wheel.
If you feel some play left and right, then it's most likely the tie rod.
If you feel some play up and down, then either the ball joints or wheel bearings.
It's easiest if one person is shaking the wheel, and someone else is under taking a look at what's actually moving.
Old Mar 19, 2003 | 11:46 AM
tpr's Avatar
tpr
Grab the tire at the top and bottom and push/pull. If there is play then its the wheel bearing. No play, not wheel bearing. Next grab the tire at the front and back and push/pull. If there is play then it is most likely the tie rod end either inner (less likely) or outer (more likely) I had the same noise/vibration. Replaced outer tie rod ends and problem went away. Be sure to check the alignment after replacing the ends. A good starting point t get back to near the perviois alignment is to count the number of turns to remove the ends and screw them back on the same number of turns. This will be close but you should have it checked anyway.
Old Mar 19, 2003 | 11:57 AM
Outsane's Avatar
Default Re: Tie rod or wheel bearing.. (tpr)
It ended up being a severly warped rotor..
Go figure..I thought I was getting a clean set of rotors..but I guess not..
My tie rod is a tiny lose so if I happen to see one I will toss on a new one..
found out the hub is bent too.. a friend is putting on EX knuckles so I will put on his stock ones..
thanks
94civiccupew/b7
23
Dec 11, 2009 06:27 AM
snatch
12
Jan 25, 2008 11:36 AM
xH22xTEGx
Suspension & Brakes
11
Jan 6, 2006 02:27 PM
alleyezonme
Suspension & Brakes
Aug 9, 2005 05:09 PM
shortyz
Mar 29, 2003 03:36 PM
