integra shift linkage question and others?????
Old Mar 17, 2003 | 07:27 AM
Mr.DC2TurBo's Avatar
Default integra shift linkage question and others?????
Hi, I'm trying to find out if a gsr shift linkage will fit on a LS without modifications? Also, can someone tell me what are the parts I need to do a complete manual swap. This is what I know so far about doing the swap..
There's the :
Tranny 5speed (LS or gsr? - which is better for TURBO????)
ECU (obd1)
shift linkage
flywheel
clutch
clutchmaster cylinder and slave cylinder
shifter/boot/****
pedals
Also, can someone tell me what are hydraulic lines and if you have a picture that be great? Thanks for the help.
Old Mar 17, 2003 | 09:08 AM
Default Re: integra shift linkage question and others????? (LS-T2001)
anyone??
Old Mar 18, 2003 | 03:23 PM
Bseries's Avatar
get the lines from another car. get it from the clutch master to the slave cylinder. don't forget to get the slave and master cylinder. if this is a 92-95 civic or integra you have to get the passenger mount from the dealer and weld that in and get a manual trans mount and helper mount and change the rear engine mount bracket to a 5spd one. you are going to need to do some wiring for taking out the ignition key and the reverse lights. don't forget the throttle cable if going to a different motor.
Old Mar 18, 2003 | 03:24 PM
Bseries's Avatar
oh and yes the ls and gsr linkage is the same and as for trans if ls stay ls but if you lsvtec then go gsr.
scatterbrain756
Dec 15, 2010 02:00 PM
nfinitecc
Mar 15, 2009 11:58 AM
eyece
Nov 10, 2005 05:28 AM
Bspec18
Jul 22, 2003 11:32 AM
Mr.DC2TurBo
Mar 17, 2003 09:57 AM
