D series block question.....
Old Mar 17, 2003 | 06:24 AM
Petah's Avatar
Default D series block question.....
Is a 2000 DX SOHC, 1.6L block be the same as a 92 SI SOHC VTEC block? I am only talking about blocks here as i am trying to put the 2000 motor into a 92 civic. Trying to figure out what mounts will i need to use. Thanks.
Old Mar 17, 2003 | 06:37 AM
eg6ajk's Avatar
Default Re: D series block question..... (eg-six)
yes the block are pretty much identical, yes you can swap in a y7 or y8 into a EG or EF. tranny will work as well
Old Mar 17, 2003 | 06:42 AM
Spade's Avatar
Use the SI mounts.
Old Mar 17, 2003 | 06:45 AM
Petah's Avatar
Default Re: D series block question..... (eg6ajk)
Hey Adrian! Thanks for the info. But this means i will need part #8 in the below picture that is for a 92 SI, SOHC VTEC....right? What abotu rear mount? Will the one from the EK work? Or will i also need to order the one for the 92 SI? Thanks.
Old Mar 17, 2003 | 06:46 AM
piscorpio's Avatar
I was wondering the same thing. Are they identical, or almost? I have wanted to work with a d16y8/z6 block, but if a DX, CX block are available is it really just as good? Are there any differences that make the EX/Si blocks better?
Old Mar 17, 2003 | 06:51 AM
TurbodCX's Avatar
Default Re: D series block question..... (piscorpio)
NO!! they are not identical, the drivers side torque mount with not bolt up to the 96-up blocks, only three of the bolt holes line up!. and the rear main seal housings are not interchangable between them..
I know all of this because i have a 98 D16Y8 in my 94 hatch!
Brian
Old Mar 17, 2003 | 06:53 AM
TurbodCX's Avatar
Default Re: D series block question..... (TurbodCX)
Oh yeah and also the 96-up have the dipstick built into the oil pump housing, and the 92-95 have them in front of the block, i had to drill the block i have, and make the dipstick tube from a 92-95 fit it.
Brian
Old Mar 17, 2003 | 07:03 AM
piscorpio's Avatar
Other than fitment issues, is there anything internally or design related that makes the EX/Si better (asides from pistons/rods)?
Old Mar 17, 2003 | 07:09 AM
Petah's Avatar
Brian
Torque mount? What part is this? Is it part #8 in the picture above? Which torqure mount are you using? EG or EK one? If you are using the EK one, can't i order the one for the EG and bolt that on? As far as the dip stick issue, why will i need to worry about it since i will using the dip stick from the 2000 anyways....something i am not aware of? Thanks.
[Modified by eg-six, 8:10 AM 3/17/2003]
Old Mar 17, 2003 | 07:15 AM
TurbodCX's Avatar
ok, you wont have to worry about the dipstick issue if you are using the whole motor,, and the #8 mount is fine, the mount that doesnt fit is the mount that fits on the driver side front of the engine, it is the mount that the AC Comp. bolts to.
Right now i have Si mounts from a 92-95.
Brian
Old Mar 17, 2003 | 07:23 AM
4g4me's Avatar
To avoid all confusion, use all the mounts and mount brackets from the corresponding vehicle that the motor is going into. IE, all the mounts from the EG, including block mount brackets should be used with the y7/y8 block.
Same goes for EF civics too.
Old Mar 17, 2003 | 07:26 AM
TurbodCX's Avatar
Default Re: D series block question..... (4g4me)
why?? the Eg mount doesnt fit the Y7-Y8 block properly so why use it??
I would think you should try to use the mounts that fit the corresponding motor.
Brian
Old Mar 17, 2003 | 08:26 AM
nerdsports's Avatar
i have a d16y7 in my 95 dx. the drivers side "torque" mount from my DX fit perfect. i dunno what u keep talking about man.
Old Mar 17, 2003 | 09:48 AM
TurbodCX's Avatar
Default Re: D series block question..... (nerdsports)
well i have a D16Y8 block into a 94 CX and the damn mount that the AC condensor hooks to did not fit perfectly..
Also i put a 95 motor into a 97 DX and the mount from the 97 did not fit perfectly either..........on the 95 block!
So either you have #1) special honda mounts, or #2) you dont know what you are talking about and #3) you are using the mount from the 96-up motor.
Brian
Old Mar 17, 2003 | 05:20 PM
nerdsports's Avatar
#1) special honda mounts? uhh ok guy... #2) i DO know what im talking about... i dunno whats up with ur **** #3) im using my '95 DX mounts.
I'll snap some pictures so u can see for urself...
spoonef
Northwest (Sales)
Apr 1, 2006 01:44 PM
prada_G
Texas -OK -LA (Sales)
Jan 26, 2006 01:22 PM
93formula
Jan 13, 2005 06:50 PM
