EK 5-Lug Conversion, Which Booster/Master Cylinder?
Old Mar 17, 2003 | 05:49 AM
Rising Sun's Avatar
Default EK 5-Lug Conversion, Which Booster/Master Cylinder?
I am doing a 5-Lug conversion on my EK hatch, and I was wondering what brake booster and master cylinder to use. Will 2000 ITR booster and master cylinder work? Also anyone know what proportining valve to use?
Old Mar 17, 2003 | 06:37 AM
jonas's Avatar
Default Re: EK 5-Lug Conversion, Which Booster/Master Cylinder? (Rising Sun)
itr one will work.
use a 99-00 si prop valve, its not NEEDED though. you can use your cx/dx one if you want.
Old Mar 17, 2003 | 08:09 AM
SW20 MR2's Avatar
Search button is your best friend. This is discussed almost weekly. :D
Old Mar 17, 2003 | 08:59 AM
Newman's Avatar
New User
Default Re: EK 5-Lug Conversion, Which Booster/Master Cylinder? (jonas)
itr one will work.
Correct, ITR will work since it's 1", while the GSR MC is 15/16"
If you really want a 40/40 prop valve, they come on non-ABS 90-93 Integras and are pretty easy to find.
Old Mar 31, 2003 | 03:05 PM
FritzInTN's Avatar
Default Re: EK 5-Lug Conversion, Which Booster/Master Cylinder? (Newman)
itr one will work.
Sorry to revive this thread. But I put a JDM ITR master cylinder and ran into some problems. The first being that the hole for the brake lines were on the 'wrong' side so clearance was an issue. The worrysome part was that one of the line sizes were different. I was going to just pick up a USDM ITR one however I'm not sure how to resolve the different size brake line issue.
Old Mar 31, 2003 | 03:18 PM
cre18's Avatar
Default Re: EK 5-Lug Conversion, Which Booster/Master Cylinder? (FritzInTN)
itr one will work.
i did a gsr brake conversion on my ek, 4-lug not 5, and used a usdm mc and bb. i didn't run into any problems with the brake lines. i never swapped out my dx prop valve, no problems using it so far
Old Mar 31, 2003 | 05:35 PM
civic23g's Avatar
In japan the pedal assembly is on the other side, hence the line not fitting.
Old Mar 31, 2003 | 05:37 PM
Chris y0!'s Avatar
Default Re: EK 5-Lug Conversion, Which Booster/Master Cylinder? (civic23g)
lol, H-T detective skills hard at work
Old Mar 31, 2003 | 06:01 PM
FritzInTN's Avatar
Default Re: EK 5-Lug Conversion, Which Booster/Master Cylinder? (Spoon Hybrid)
Lol, the line *could* fit, however the actual fitting size , and even the brake line itself is larger on one of the lines. I'm wondering if the difference in line *size* is different on the USDM ITR one.
jDMJeRk
Nov 13, 2006 06:14 PM
sleepyhamsterlx
53
Jan 28, 2005 09:30 PM
SpoolinEK
May 10, 2004 11:26 AM
_unknown_
Nov 21, 2001 09:54 PM
