check engine light is on
MY Check Engine light is on and I Have (9) LIGHT FLASH.
In my Book IT Said the #1 CYC. And my car RUN FINE. IF YOU CAN GIVE ME WHAT YOU THINK IS WRONG PLEASE.
Distributor is going out soon...bearing in the dizzy heats up and cause cyl position sensor inside the distributor to heat up too, reason for code 9. If your car's running fine, i wouldnt worry about it too much except prepare to replace your dizzy soon. http://www.geocities.com/chipman_13/...shoot.html#CAS
Stephen122193
Jan 2, 2012 02:45 PM
Neo218
Apr 6, 2010 10:19 AM
