Which cams do you recommend?
I currently have i/h/e, I now want to move to the next modification. I'm looking into some cams but not sure which ones to get. I'm thinking about skunk 2 or toda b spec. I was told the type r cams or stage 1 cams will be a little on the mild side. I was wondering how much real power I would gain with stage 2 cams? Besides just dropping in the cams, what else is a must that I would need to compliment the cams? I don't plan on changing any internals just yet. I appreciate your responses.
If you are going to go with the stage 2s (or any other aggressive cams for that matter) it would be a good idea to bump up your compression. High lift cams love high compression.
check out these sites. depends on what your goals are. personally, i'm looking for something mild and want to avoid changing my internals. the sites below provide some good info.
http://www.jdmfan.com/articles/itr-cams_analyzed/
http://www.importreview.com/performance.html
Yes, upgrade your valve train if you are going with the Todas or Stage 2s. To take full advantacge of these aggressive cams you will want to raise your redline.
check out http://www.ef-1.com they offer cams and valvetrain and different applications depending on what your going for.
If you are not going to upgrade your valvetrain, don't go with anything more aggressive than ITRs. You won't get any power out of the more agressive cams, unless you do some upgrading. Even Toda A's, and Skunk2 1's need at least an ITR valve train to put down some decent power.
The Skunk2 Stage 1's are much different than itr cams...
Ruben19
Jan 24, 2006 07:25 PM
