[FAQ] DIY Polyurethane Motor Mounts
Old Mar 17, 2003 | 04:00 AM
keithv's Avatar
Default diy poly mounts
ok i got this idea from stevel, so thank him for this how-to.
first you buy some poly glue. i got this at lowe's. it was like $5.
then you put it in the mount (i had duck tape on the back side so it wouldn't squeeze through).
don't remove the tape for 24-48 hours when the glue is finally dry. i didn't wait and ripped the tape off after 12 hours. i ended up ripping the somwhat dry skin off the poly. the wet poly was underneath and not dry yet. so be patient and wait!
a review of the mounts to come in a few weeks.
Old Mar 17, 2003 | 06:33 AM
USDM 4G VTEC's Avatar
Default Re: diy poly mounts (breaka_1_9)
i have done that before
actually works good and stiffens the engine pretty damn good....
but what i did..... since i had to use the mounts in 8 hrs.... i baked them on a BBQ grill.... for 4 hrs.... they dryed pretty qwuick......
but lik eu said, the longer u wait, the better....
Old Mar 17, 2003 | 07:15 AM
keithv's Avatar
Default Re: diy poly mounts (USDM 4G VTEC)
i was going to put them in an oven to try and speed the process up but didn't want to stink up the house. the grill idea sounds good! ...wish i would have thought of that.
one thing to add. i should have filled the side with tape first, then added the tape. i noticed when i took the tape off that the mount wasn't completely full. i just wanted to strengthen up a beat mount so i think i got enough in there to help.
Old Mar 17, 2003 | 07:58 AM
Eggman's Avatar
Another reference for DIYers http://importnut.net/motormount.htm.
Old Mar 17, 2003 | 08:35 AM
loclowd's Avatar
Default Re: diy poly mounts (Eggman)
I did the same thing, and it saved my life...when I got in an accident, it prevented my engine from coming up in my lap, instead, the sir2 just bounced back and forth
Old Mar 17, 2003 | 08:45 AM
keithv's Avatar
yeah but the poly glue is cheaper.
Old Mar 17, 2003 | 09:08 AM
incubus's Avatar
you could always put a small peice of tape on the back of the other tape so it doesnt stick to the poly and possibly rip it off.
Old Mar 17, 2003 | 09:11 AM
zcivicz's Avatar
can you do this to the rear bushings too ? cuz i noticed the trailing arm bushings are ripped apart and you can see through them!
Old Mar 17, 2003 | 09:25 AM
Eggman's Avatar
Default Re: diy poly mounts (zcivicz)
That's what I'm planning on doing. Soon as I get the time...
Old Jun 11, 2003 | 12:09 PM
Zer0DazE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zcivicz &raquo;</TD></TR><TR><TD CLASS="quote">can you do this to the rear bushings too ? cuz i noticed the trailing arm bushings are ripped apart and you can see through them!</TD></TR></TABLE>
did anyone try this yet?
Old Jun 11, 2003 | 12:21 PM
raene's Avatar
Default Re: diy poly mounts (Zer0DazE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zer0DazE &raquo;</TD></TR><TR><TD CLASS="quote">
did anyone try this yet?</TD></TR></TABLE>
Exactly the same thing I was thinking...
Old Jun 11, 2003 | 12:32 PM
keithv's Avatar
Default Re: diy poly mounts (raene)
it cost $5 for the glue, so you might as well go ahead and try it.
i might do this to my car for an interin fix (but don't hold your breath on when i'll get around to doing it). it should hold me over until i can get the mugen TA bushings in there.
Old Jun 11, 2003 | 12:42 PM
Timmah!!'s Avatar
Default Re: diy poly mounts (keithv)
I did this to my mounts when I did my swap a couple of weeks ago. It worked really well, and I want to try to do it do the rear bushings too, but havent had the time.
Old Jun 12, 2003 | 09:32 AM
JCracer723's Avatar
what's best? some poly glue or 3M's window weld ?? or is it same thing??
Old Jun 12, 2003 | 10:19 AM
keithv's Avatar
Default Re: diy poly mounts (JCracer723)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCracer723 &raquo;</TD></TR><TR><TD CLASS="quote">what's best? some poly glue or 3M's window weld ?? or is it same thing??</TD></TR></TABLE>
i haven't used the window weld so i can't say. the poly glue is $5 at lowe's/home depot...i think the window weld is around $15 (from what i have heard). if that's the case, the poly glue is better.
Old Jun 12, 2003 | 10:25 AM
JCracer723's Avatar
how long have you had your mounts like that for?? are they still in good shape? has the poly glue come out at all??
Old Jun 12, 2003 | 10:30 AM
keithv's Avatar
they weren't the mounts for my car, but a friend's car. the car is sitting in a garage collecting dust as we speak, so the mounts were never tested.
try IMing stevel and talk to him. he gave me the idea and should have some answers to your questions.
Old Jun 12, 2003 | 10:51 AM
Timmah!!'s Avatar
I have been running my mounts for about 3 weeks now, and they are great. It does get annoying having solid mounts but I like them. I used the poly glue got it for like 4 bux. One of the best DIY mods I think can be done.
Old Jun 12, 2003 | 10:59 AM
Mr Furball's Avatar
good idea
Old Jun 12, 2003 | 11:03 AM
EL Vap133's Avatar
Nice....
Old Jun 12, 2003 | 11:22 AM
JonGP4's Avatar
i used clear silcone, it worked good, still flexs alittle and i've had the front dont on my accord for about 8 months still good. I just recently did my civic's front and rear mounts, we will see how they stay.
Old Jun 12, 2003 | 11:46 AM
b16_madman's Avatar
is this the one that kinda connects to the body/frame in front of the rear wheel well. if so, when i did my springs i bent it too much and now they squeak like no other. I don't know if this would help, but it's worth a try. I might ghetto it and leave it all in and not take the mount out...or just by some new mounts...i dunno.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keithv &raquo;</TD></TR><TR><TD CLASS="quote">ok i got this idea from stevel, so thank him for this how-to.
[then you put it in the mount (i had duck tape on the back side so it wouldn't squeeze through).
[don't remove the tape for 24-48 hours when the glue is finally dry. i didn't wait and ripped the tape off after 12 hours. i ended up ripping the somwhat dry skin off the poly. the wet poly was underneath and not dry yet. so be patient and wait!
keith v...btw they just did this in sport compact car to their sentra se-r...if anyone besides me noticed...good idea though.
Old Aug 16, 2003 | 02:40 PM
cpforyou's Avatar
Doing this on my Civic right now. Lets see how it all works out.
Old Aug 16, 2003 | 02:49 PM
Hcivic88's Avatar
Default Re: diy poly mounts (B16_madman)
[QUOTE=B16_madman]
QUOTE]
yeah, thats the one hes talking about. and about buying some new ones, good luck, i tried honda and they couldnt even get them... although they said that they're supposed to flex a lot, and that you should be able to see through them, since they have like spoked. so I decided that mine wernt actually bad and just kept them in there.
Old Aug 16, 2003 | 02:50 PM
Loaded Butane's Avatar
Default Re: diy poly mounts (cpforyou)
Since we are bringing up old posts...
I have had my mounts filled for almost a year and they are holding up just fine. I have 2 mounts fitted with ES mount inserts and the other 2 are filled.
