any1 know the torque specs for the spark plugs? for a 97 gsr
Old Mar 16, 2003 | 09:48 PM
97gSrkId88's Avatar
Default any1 know the torque specs for the spark plugs? for a 97 gsr
im putting in new plugs and im wondering what are the torque specs for putting in the spark plugs? its for a 97 gsr
Old Mar 16, 2003 | 10:04 PM
Understeer's Avatar
Default Re: any1 know the torque specs for the spark plugs? for a 97 gsr (97gSrkId88)
13lbs/ft
Old Mar 16, 2003 | 11:01 PM
Trac226's Avatar
Default Re: any1 know the torque specs for the spark plugs? for a 97 gsr (Understeer)
I keep mine at 20ft-lbs
Old Mar 16, 2003 | 11:15 PM
intekragsr's Avatar
Default Re: any1 know the torque specs for the spark plugs? for a 97 gsr (Trac226)
use 13 pounds.
Old Mar 17, 2003 | 03:43 AM
Loveless's Avatar
what happen if you don't? I tightened it as hard as I could. At least 20lb for sure
Old Mar 17, 2003 | 06:15 AM
JimBlake's Avatar
Default Re: any1 know the torque specs for the spark plugs? for a 97 gsr (Loveless)
You might have a real hard time getting them out next time. Check out some HeliCoils 'cause you might pull the threads out of the head when you try to remove the plugs.
If you're lucky, you'll be just fine.
jvr
Apr 26, 2014 02:24 AM
mynameizstitch
Jun 22, 2009 08:32 PM
JDMfrontedLS
Mar 30, 2006 09:11 PM
ITRFetish2000
May 9, 2004 06:47 PM
paulyman
May 20, 2002 07:11 PM
