Removing Motor Mount Bolt?
Old Mar 16, 2003 | 08:37 PM
AllMotorHB's Avatar
Default Removing Motor Mount Bolt?
Swapping in a b20 in my 98 hatchback soon. Im suppose to use the Civic Si bracket on the driver side motor mount. I says to reuse the old civic studs in the new mount. Just wondering how do I remove the stud out of the old bracket. I tried hammering it out until I realized it was screwed into there.
Old Mar 16, 2003 | 09:08 PM
97hb's Avatar
Default Re: Removing Motor Mount Bolt? (AllMotorHB)
I just bought new studs at like $6 each or 12 for the 2. You can use two bolts on the stud and tighten them together, then use a wrench to remove the stud. Kinda hard to explain without a pic
Old Mar 16, 2003 | 09:20 PM
AllMotorHB's Avatar
Default Re: Removing Motor Mount Bolt? (97hb)
Do they have the studs in stock at the dealership? Last time I was looking for a bolt, all the dealerships around here said they dont really keep hardware in stock. or Do you have a part #?
Old Mar 16, 2003 | 09:23 PM
eg_nezay's Avatar
do u know how to do the 2nut trick to remove the studs? like mentioned above, kinda hard to explain.
Old Mar 16, 2003 | 09:26 PM
AllMotorHB's Avatar
Default Re: Removing Motor Mount Bolt? (eg_nezay)
yea I think I got it. Tighten the two nuts together and the start turning the bottom one. It should have no where to go because of the nut on top of it making the stud turn. Hopefully that works but if not I want a plan B which is new studs.
Old Mar 16, 2003 | 09:28 PM
eg_nezay's Avatar
Ill try my best to explain...
put a nut on the stud like normal, then put another nut upside down.
Screw the nuts together then tighten them. After they are tighten, just unscrew them like u would normally.
Did u get that?
Old Mar 16, 2003 | 09:31 PM
eg_nezay's Avatar
ok, u beat me to my post.
But yea, thats what u do and should work.
Old Mar 16, 2003 | 09:33 PM
AllMotorHB's Avatar
haha cool. thanks for the tip guys. Sounds like it should work.
ConceptVBS
Honda Civic (2001 - 2005)
Apr 17, 2014 06:14 AM
SIRIUS VTEC
Aug 9, 2010 11:53 PM
Hondaaaaa
Apr 14, 2009 06:24 PM
b18b1turbo
Apr 13, 2008 01:53 PM
tozwp
May 4, 2005 03:49 PM
