Upgrading from oem alarm on an R
Old Mar 16, 2003 | 05:40 PM
danelot's Avatar
Default Upgrading from oem alarm on an R
I posted this in the alarm form, but didn't quite get an answer https://honda-tech.com/zerothread?id=433888
I have an oem alarm and want to upgrade it. I stopped by a shop that seemed pretty good. They are willing to customize the install to my prefences. However, I inquired about removal of the oem alarm. They told me they usually just leave them in. If it came from the factory, I could understand this being part of the car's factory wiring. Since the alarm is an accessory shouldn't it be removed? It seems half assed to leave it in. Has any anybody upgraded and had the oem unit removed?
Thanks
Old Mar 16, 2003 | 05:43 PM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: Upgrading from oem alarm on an R (danelot)
what oem alarm? leave it in....
Old Mar 16, 2003 | 05:53 PM
danelot's Avatar
Default Re: Upgrading from oem alarm on an R (RealTypeR)
I the guy I bought the car from had Acura install it when he bought it.
Old Mar 16, 2003 | 06:39 PM
Eric R's Avatar
If you're talking about an ITR, no ITR came with an OEM alarm. It's just a keyless entry system from factory. You can install any aftermarket alarm to it and leave the keyless module in it. It won't interfere. You can put the factory keychains away and use in case you lose your alarm remotes or get locked out.
Old Mar 16, 2003 | 06:49 PM
danelot's Avatar
Default Re: Upgrading from oem alarm on an R (Tweety R)
I guess I'm miss using oem. I mean it's just a factory alarm
Old Mar 16, 2003 | 09:42 PM
SoCal ITR's Avatar
The alarm is a dealer accessory.
I have an aftermarket alarm in addition to my factory alarm. I use both, so that even if one is disabled, the other will go off. If I don't unlock them almost simultaneously, they will go apeshit.
There's no reason to remove the stock unit. My alarms are almost seperate entities, aside from what they monitor.
Old Mar 16, 2003 | 09:46 PM
B2FiNiTY's Avatar
Default Re: Upgrading from oem alarm on an R (SoCal ITR)
ape ****! hahaha, so true.
Keep both if you can. Doesn't hurt
John M
Mar 31, 2008 07:49 PM
sk8shorty012
Audio / Security / Video
Jun 30, 2007 07:16 AM
HRPfg2
Honda Civic (2006 - 2015)
Jul 5, 2006 09:23 PM
rtpassini
Aug 4, 2005 02:59 PM
Carloscda37
Jul 19, 2005 03:06 PM
