I replaced fuel filter but...
I replaced distributor cap/rotor (not related) and fuel filter but I don't a torque wrench, so I just tighten it as hard as I can (I am only 150lb)
I then start the engine, let it sit until it's warm (until the idle drops) and I checked the fuel line and I don't notice any leak. I drove to the market and back and still don't notice any leak.
Should I be worried that It's too tight or too loose? Also I didn't use all of the washer it came with. The fuel filter came with 2 large and 1 small. I couldn't figure out where the small one go so I didn't install it. Where does it go anyways? It's a honda oem part, by the way.
yeah I didn't use the small washer either. There wasn't one in there in the first place. I think it was for older models.
If it wasn't leaking it should be ok. I noticed that the filter and bolt had markings to help line them up at the right torque so I marked the new filter at the same spot and tightened them until the marks lined up. Actually, I couldn't line up the bottom but it has been ok
Search...This has been coverd because I searched when this happened.
older tegs had like a release bolt or something on top of the banjo bolt. Thats what the lil washer is for.
My 94 has a 10mm service bolt that goes into the middle of the larger banjo bolt. I guess the later ones don't have that?
[Modified by ragejed, 8:52 PM 3/16/2003]
Mini-mEK4
14
Jul 18, 2004 10:43 AM
