I need torque Specs!!!
Old Mar 16, 2003 | 04:49 PM
1hotintegra's Avatar
Default I need torque Specs!!!
hey, i did my suspension last week and couldnt torque anytying cuz i didnt have a torque wrench...i know its not the smartest thing to do but anyway.... im putttin different struts in in the next couple days and this time im gunna torque them to spec so, can someone gime me the torque specs for the bolts on the suspension??
Old Mar 16, 2003 | 05:58 PM
Default Re: I need torque Specs!!! (1hotintegra)
anyone
Old Mar 17, 2003 | 12:52 AM
slomob18b's Avatar
hmm can you be more specific as to which bolts you need the specs for? refer to: http://www.bseries.net/html/garage/spring.php and let me know which bolts.
Old Mar 18, 2003 | 05:41 AM
Default Re: I need torque Specs!!! (slomob18b)
for the front:
the 14mm bolt at the top of the fork, the 17mm lca bolt
for the rear:
the 14mm bolt at teh base of the rear shock
the 14 mm bolt at the lower part of the locating arm
and:
the 14mm nuts at the top of the shock under the hood and in the trunk
thanks
Old Mar 18, 2003 | 06:13 AM
IN VTEC's Avatar
for the front:
the 14mm bolt at the top of the fork[32lb*ft], the 17mm lca bolt [47lb*ft]
for the rear:
[all the bolts on the LCA's are 40lb*ft except swaybar bolt (it's 29lb*ft)]
and:
[all are 36lb*ft]
Old Mar 18, 2003 | 08:41 AM
Default Re: I need torque Specs!!! (IN VTEC)
thanks
D50boy
Apr 24, 2008 12:28 PM
passwordT
Feb 16, 2005 04:40 PM
S13Koop
Nov 18, 2001 03:41 PM
