Sun roof motor - slow as sh-t
Old Mar 16, 2003 | 04:44 PM
2000gsrsedan's Avatar
Default Sun roof motor - slow as sh-t
I press the button and the sunroof barellllllly open and closes....sometimes I have to help it. Anyone ever replace this?
Old Mar 16, 2003 | 04:46 PM
scrap1ngsr's Avatar
Default Re: Sun roof motor - slow as sh-t (2000gsrsedan)
i had the same problem and just sprayed some wd40 on it and it was okay...try it spraying that
Old Mar 16, 2003 | 04:51 PM
Default Re: Sun roof motor - slow as sh-t (CivicSiR94)
ill try that tomorrow thanks.
Old Mar 16, 2003 | 05:05 PM
b00sted4dr's Avatar
Why is it when its cold, my sunroof sometimes doesn't open? It only happens on cold nights and needs an extra push for it open.
Old Mar 16, 2003 | 05:12 PM
AWDxBOOST's Avatar
the teg windows are so slow....
Old Mar 16, 2003 | 05:14 PM
Seedc2's Avatar
Default Re: Sun roof motor - slow as sh-t (ls_teg)
i heard wd40 isnt good to apply. Rather lithium grease, it goes for 1.99 at autozone. I gotta pick some of that up soon
Old Mar 16, 2003 | 05:16 PM
timmy8151's Avatar
Default Re: Sun roof motor - slow as sh-t (kendogg)
Yup, I use white lithium grease to lubricate my sunroof rails. You can use WD40 to clean, but don't use it as the only lubricant.
Old Mar 16, 2003 | 05:22 PM
integobsession's Avatar
Default Re: Sun roof motor - slow as sh-t (timmy8151)
Yup... cuz it dries! Me and my roommate, Pdcdragon, put some lithium grease on his sun roof and it opens really well... it used to rattle before. (But his window never had a problem with opening too slowly.) At any rate... it doesn't hurt your car!
Old Mar 16, 2003 | 06:46 PM
illi Adik's Avatar
I had the same problem a couple days ago, it would even shutter, I had to help it close. WD-40 did the trick, its opening and closing better too because its warm.
Old Mar 16, 2003 | 06:57 PM
HONDAS SUCK
Guest
Posts: n/a
you need a new motor. Dam Jap cars. Shoulda went American. My sisters boyfriend has one dem damn integras. He had 3.
Old Mar 16, 2003 | 07:32 PM
Jesse H's Avatar
Default Re: Sun roof motor - slow as sh-t (HONDAS SUCK)
No ****. I'm junking my Integra and getting a Z06.
Jesse H's Avatar
Use lithium grease and not wd40. Wd40 is a good cleaner, but it'll eventually leave the rails very dry and unlubricated. Bad.
Old Mar 16, 2003 | 07:39 PM
koco's Avatar
No kidding? I should buy a Cavalier or other "american" car and enjoy replacing all the overseas parts on it when the fail prematurely by the "planned obsolescence" standard. By the way, my HONDA is made in the US. If you don't believe it, look at the driver's door jamb. Printed there is MADE IN USA. You should get your facts straight before spouting off.
As for the WD40, it melts the grease off the track and is not recommended. White lithium grease is the ticket.
Old Mar 16, 2003 | 07:44 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Sun roof motor - slow as sh-t (koco)
Hmm my Honda was built in Japan... but I vote BAN on that user above.
Old Mar 16, 2003 | 08:50 PM
illi Adik's Avatar
I think people like this clown create a membership just to talk like a ******* idiot on here.
Old Mar 16, 2003 | 08:55 PM
94TealGSR's Avatar
Just lube the rails with grease, it'll work like a charm!
Old Mar 16, 2003 | 09:18 PM
Sukebei Oni's Avatar
Default Re: Sun roof motor - slow as sh-t (94TealGSR)
lube up the moving parts and then clean the sealing area. when it gets dirty and sticky the cold weather can make it hard for the roof to open. cleaning the rubber seal around the edge helped mine a lot.
Old Mar 17, 2003 | 07:54 AM
Chris's Avatar
Banned.
Old Mar 17, 2003 | 08:02 AM
Chris's Avatar
Default Re: Sun roof motor - slow as sh-t (Chris)
Now, back on topic.
Lithium grease is all you should use.
DannyBoy310
Oct 30, 2011 04:02 AM
jeffrox626
Mar 4, 2011 05:55 AM
Dekorum
Jun 28, 2008 08:46 PM
taffetawhitegsr
Jul 23, 2004 10:37 AM
TeamTooQuick
Mar 11, 2002 06:54 AM
