Can someone tell me how to hook up self amplified tube to stock RSX-S?
Old Mar 16, 2003 | 03:15 PM
Revtoredline's Avatar
Default Can someone tell me how to hook up self amplified tube to stock RSX-S?
I am having trouble hooking up a 200 watt tube subwoofer to my stock Bose unit. My tube has 4 total inputs, a + and - speaker input, a 12 volt input and a ground. I want to try to use set-up going to the stock subwoofer. TIA
Old Mar 16, 2003 | 03:49 PM
rjr162's Avatar
Default Re: Can someone tell me how to hook up self amplified tube to stock RSX-S? (Revtoredline)
have fun. I tagged it off the bose amp under the passenger seat. The wires you need are like... (if this formats right)
_______________________
|.................................XX |
|__XX__________________|
something in that area of the plug. IN the middle are a bunch of thin wires.. i found the rear speaker lines as the first thick wires you hit after the middle thin wires.
(ignore the dots, if i didn't put them the format would mess up)
[Modified by rjr162, 3:17 PM 3/17/2003]
Old Mar 17, 2003 | 05:16 AM
TurboBumblBee's Avatar
your tube has 4 total inputs supposed to be a signal wires off the radio.. what you can do is wire all the negatives to 1 strand, and all the pos to another strand so you only have 1 input that would be neg and positive.. then at your bose sub connection you take the left and right input and connect the two.. i forget the color wires thats at the stock sub connection but this is all you need to do..
Old Mar 17, 2003 | 05:23 PM
Default Re: Can someone tell me how to hook up self amplified tube to stock RSX-S? (rjr162)
I cannot follow your diagram..I guess I know less than i thought. Anyway, would it be easier for me to remove the pass. seat. because I cant see a darn thing down there and there seems to be several sets of wires to the amp and I 'm not sure which is coming or going. DO you have or know where I can get a wiring diagram of it?
janek
Apr 8, 2013 03:37 PM
twiztid00002
Aug 24, 2008 10:57 AM
deerman2701
Audio / Security / Video
Feb 14, 2008 04:35 AM
imadigitalgod
11
Oct 30, 2004 12:32 PM
VSM Trigger
Feb 2, 2003 09:13 PM
