Clutch and gear problems, HELP!!!
Old Mar 16, 2003 | 06:38 AM
JunIntegra's Avatar
Default Clutch and gear problems, HELP!!!
when start engaging the clutch to get out of 1st,i hear a "click" and also in some other gears too. also after rolling in 1st gear then suddenly disengaging the clutch, i hear it click twice like its stumbling or something.
Also, my 2nd,3rd and somtimes 4th feel a little notchy. i bought the car in oct,and onlyt 2nd did i a lil bit, now it got worse and ive barely even beat on it. its winter here so could that be it? please help, thanx!
Old Mar 17, 2003 | 08:18 AM
spoon94gsr's Avatar
Default Re: Clutch and gear problems, HELP!!! (JunIntegra)
could be your master and salve cylender. have those checked b4 you mess up some of the syncros if thats the problem...
if theres really no presure in the clutch it couldbe the master but if thats thecase for lke 140 yu can get a new slave and master cylender...
ihad the same problem but i out all new stuff in now...
Old Mar 17, 2003 | 11:23 AM
dip-set's Avatar
Default Re: Clutch and gear problems, HELP!!! (spoon94gsr)
i dont know if its the same but my clutch pedal makes a click sound when i press on it whether its in gear or not and as im releasing it ckicks again..checked everything and it seems fine as other members here stated its a problem that comes and goes..its not serious but more annoying hearing the click in the car when the radios not on...sounds like a spring or something of that sort making the clicking sound...."in the car not outside the car" ...outside the car u hear the throw out bearing or release bearing engage ,disengage...dont my my mechanical terms...im not a mechanic..jusst trying my best to explain/ maybe help u out....
Old Mar 17, 2003 | 01:50 PM
MisterHYBRID's Avatar
Default Re: Clutch and gear problems, HELP!!! (teg-your-it)
could be spring loose in the clutch.
Old Mar 17, 2003 | 02:03 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: Clutch and gear problems, HELP!!! (MisterHYBRID)
Could be as simple as you need more oil in the tranny. I found that out this weekend. But my tranny was bad anyway.....main-bearing. New GSR tranny now.
Old Mar 24, 2003 | 12:47 PM
JunIntegra's Avatar
Default Re: Clutch and gear problems, HELP!!! (HybridcivicLS-T)
well thanx guys, but i recently put in a new clutch and flywheels hoping it would resolve some fo these problems. it was great at first but as miles built up, it came back. and through out the winter since nov., it was only 2nd gear that crunched at first but now it got to 3rd and a lil in 4th smetimes.i havent beaten on thecar really and only put 2000 miles on since november. so im cluless
old_school_dohcvtec
Oct 4, 2007 09:47 AM
candy eg
Jan 11, 2006 08:22 AM
RainingRed24
Oct 11, 2005 01:47 PM
