individual throtle body's good or bad?
Old Mar 15, 2003 | 09:00 PM
playAho's Avatar
Default individual throtle body's good or bad?
I was thinking about doing individual throtle body's. partly because I would like to make the engine bay look cleaner and get rid of some of the vacume lines and stuff on the fire wall. and partley bacause I herd they add alot more power to your car. but I haven't had any experience with them and haven't herd much about them. so I was wondering if anyone could tell me more about them the good the bad and what you would do. ow it is going on a b16 motor in a 92 hatch back cx if that is any help! thanks
Old Mar 15, 2003 | 09:02 PM
B2FiNiTY's Avatar
Default Re: individual throtle body's good or bad? (playAho)
You definately need more research about ITBs. It does not sound like you need them or are ready for them right now.
jonas's Avatar
ITB's to clean up vacume lines? that is the last thing you want to worry about when chosing ITB's lol.
ITB's aren't for just anybody, the ITB's alone burn a whole in one pocket, and the tuning involved needed to get it running right... especially on the street, is a hole in the other pocket.
you want to make your engine bay look cleaner? take your motor out.
Old Mar 15, 2003 | 09:07 PM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
Default Re: individual throtle body's good or bad? (jonas)
itb's=good for highly modified engines...i doubt they would make much on basically a stock b16....itbs=bad for gas mileage
Old Mar 15, 2003 | 09:36 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
sweet jesus, itb`s are a bling item now.
Old Mar 15, 2003 | 09:46 PM
IM ALL BOB's Avatar
Default Re: individual throtle body's good or bad? (vtecvoodoo)
it's just another sad day on HT
Old Mar 15, 2003 | 09:59 PM
R you serious's Avatar
Default Re: individual throtle body's good or bad? (IM ALL BOB)
yep
Old Mar 15, 2003 | 10:06 PM
IS3Fifty's Avatar
Default Re: individual throtle body's good or bad? (CiRcUiTsi)
exactly, Its a pointless money venture for you.
Old Mar 16, 2003 | 12:52 AM
qtiger's Avatar
Ahahahahahahahahahahahahahahahahahahahahaha.
You'll have double the vacuum lines with ITBs. Not to mention check valves out the yinyang.
Old Mar 16, 2003 | 09:42 AM
playAho's Avatar
thanks! that is what I needed to hear do you know anywhere where I can read about them.
Old Mar 16, 2003 | 09:45 AM
playAho's Avatar
Default Re: individual throtle body's good or bad? (B2FiNiTY)
where can I fiend info on them? ben looking and can't fiend any. thanks
Old Mar 16, 2003 | 09:48 AM
Nextelbuddy's Avatar
i have a question about individual throttle bodies, if u have them dont u risk having bad things being sucked into your motor since u are no longer running an airfilter, or is there like sum kind of screen on each one that prevents that?
Old Mar 16, 2003 | 09:51 AM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Default Re: individual throtle body's good or bad? (nextelbuddy)
They make individual filters and filters that will cover all four.
They also make induction boxes that you can hook a tube to and run to wherever you want and stick a filter on the end.
Old Mar 16, 2003 | 09:52 AM
Default Re: individual throtle body's good or bad? (SkyeC)
ah ok thanx for that info i was just curious thats all i dont think that setup is good for me on the street lol ill stick with the norm
Old Mar 16, 2003 | 11:33 AM
RenoRacing's Avatar
when done right they are amazing. my friend evilxkid has a b16 with a built head in his hatch, he threw some TWM's on there and it screams, just yesterday he started putting the b20 block back in, B20/vtec w/ ITB's and stage 3 cams in a 1900lb hatchback, daily driven! His best time was 13.5 before the ITB's and B20, easily into the mid/high 12's.
Old Mar 16, 2003 | 11:37 AM
SuperTwinz's Avatar
I want to get ITBs because everyone wants them.
Old Mar 16, 2003 | 03:23 PM
playAho's Avatar
Default Re: individual throtle body's good or bad? (HavokRacing)
where can I fiend them? is there anywhere I can read about them get more info. like install, cost, where when how that kiend of thing.
ow and to they guy at the top my motor isn't stock but you are right it doesn't have anuff done to it to need ITB's but I just whant to know more about them and plan for the future. thanks!!
Old Mar 16, 2003 | 03:29 PM
LSVtecEK1's Avatar
ITB---not for street use unless your runing a fully built motor.
Old Mar 16, 2003 | 03:43 PM
JasonBlackEJ1's Avatar
if u dont know all that much about them then how come u know that they give u a lot of hp??? it doesnt make much sense to me. u still have to have all of the wires and **** even if it is a special tb. the do the same thing as normal ones. why dont u get a tb from a type r or get urs bored out and polish it if u want it to look better.
[Modified by AllShowNoGo, 6:44 PM 3/16/2003]
Old Mar 16, 2003 | 04:11 PM
SuperTwinz's Avatar
http://www.eonet.ne.jp/~z-spec/spec3.html Enjoy!
[Modified by Supertwinz, 6:12 PM 3/16/2003]
Old Mar 16, 2003 | 04:36 PM
qtiger's Avatar
Default Re: individual throtle body's good or bad? (EKCivicRacer)
Wrong.
Many cars come stock with individual throttle bodies. There's nothing 'unstreetable' about them... you just have to use a kit with properly sized throttle bodies.
Old Mar 17, 2003 | 10:18 AM
playAho's Avatar
Default Re: individual throtle body's good or bad? (AllShowNoGo)
I have talked to some people that race semie pro and they explaned it to me. it would take a 4 pages to write it all down. but I don't know much about them in the fact of how they work and how to install them. as well as it they are good for street use or not and wat the problems are with them. it isn't just the hp and the look that apeals to me it is also the increase in throtle response and the fact that I don't know much about them and I'm curious to lern more! now saying Im going to buy them or that they are good for me I just whant to know more!
Old Mar 17, 2003 | 10:20 AM
playAho's Avatar
Default Re: individual throtle body's good or bad? (Supertwinz)
http://www.eonet.ne.jp/~z-spec/spec3.html Enjoy! thanks that it what I was looking for!!!!!
singlecamslamed
Oct 2, 2010 03:53 AM
dreamreaperx
Paint and Body
14
Jun 4, 2009 06:40 AM
flamega
May 16, 2005 02:44 AM
viprcr1
Feb 7, 2004 06:15 AM
GroundZer0
Jul 17, 2003 07:59 PM
