DC sports header problems
I have a 95 ls and i bought a gsr 94-99 dc sports 4-1 header. will it fit on my car? and what about the o2 sensor there is no hole for it on the header and i though ls had the sensor on the header. can i get a hi flow cat with o2 sensor holes and put that on my car?
anyone? also if i bought a gsr 94-99 hi flow cat would that make the system work? i'll probably have to get custom b pipe though huh.
No the 94-99 gsr dc sports 4-1 header won't fit your 95 ls w/o modification. You would need to cut/weld a hole for the 02 sensor and shorten or extend the header since a 94-99 gsr cat has a different length. Since you are OBDI one you only have one 02 sensor on the header and none on the cat.
LSpimpTEC
Jun 19, 2004 12:45 AM
