my engine is seriously IDLEING, please tell me why?????
Old Mar 15, 2003 | 02:56 PM
50shotRex's Avatar
Default my engine is seriously IDLEING, please tell me why?????
i just did a swap and now my motor's idle is roaring up and down, sometimes when i move around the vacum hoses, its fine, but the hoses are in the wrong position...anybody have a solution???
Old Mar 16, 2003 | 03:57 AM
niedejb's Avatar
Default Re: my engine is seriously IDLEING, please tell me why????? (50shotRex)
Is the throttle cable too tight?
Have you tried the idle adjust screw?
If you have a vac leak it will do that.
I tried to increase my idle for the initial 30 min high idle break in by opening up the brake booster vac line. It did exactly what you are talking about, high then low over and over.
Old Mar 17, 2003 | 03:23 AM
97accordex's Avatar
Also,
open air bleed bolt on thermo housing when filling radiator. I have heard that air trapped in system can cause ilde problems cause of fast idle thermo valve on TB.
downshift3r
Sep 30, 2013 06:34 AM
footstinker
Nov 6, 2010 01:09 AM
Space Cadet
Oct 19, 2010 05:01 PM
RedStarGsr
Jan 7, 2004 12:01 PM
