Do i need a c-clamp for changing front break pads?
Old Mar 15, 2003 | 11:53 AM
TenaciousC's Avatar
Default Do i need a c-clamp for changing front break pads?
i know the rear piston justs twists in but for the fronts will i need a c clamp to compress the piston?
Old Mar 15, 2003 | 11:54 AM
tC_Dragon's Avatar
Default Re: Do i need a c-clamp for changing front break pads? (TenaciousC)
yup
Old Mar 15, 2003 | 12:11 PM
mickey513's Avatar
Default Re: Do i need a c-clamp for changing front break pads? (pdcdragon)
Old Mar 15, 2003 | 12:32 PM
integobsession's Avatar
yup
x2 (how is "x2" more than half capital letters???
Old Mar 15, 2003 | 12:51 PM
Henry HA's Avatar
HAnda-Tech Member
Default Re: Do i need a c-clamp for changing front break pads? (integobsession)
yes
Old Mar 15, 2003 | 02:23 PM
tC_Dragon's Avatar
huh??
Old Mar 15, 2003 | 03:31 PM
94TealGSR's Avatar
Indeed, you do.
Old Mar 15, 2003 | 03:35 PM
.RJ's Avatar
.RJ
Default Re: Do i need a c-clamp for changing front break pads? (94TealGSR)
Its a help, but you can also compress the piston back into the caliper by pushing on it with the flat side of a wrench.
Old Mar 15, 2003 | 04:35 PM
Jspd's Avatar
Default Re: Do i need a c-clamp for changing front break pads? (.RJ)
just use a pair of adjustable pliers. squeeze and your done.
Old Mar 15, 2003 | 05:04 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Do i need a c-clamp for changing front break pads? (Jspd)
I bought a C-clamp for pretty cheap from AutoZone. It even had a spiffy button so I could slide the clamping part, so I didn't have to crank it the whole time down onto the piston, just slide it and then turn the clamp to push the piston back in. That's by far the easiest way to do it.
Old Mar 15, 2003 | 06:10 PM
Sukebei Oni's Avatar
you can use a screw driver and pry against the old pad while the caliper is still on the spindel bracket. i've done it many times on other cars. but not a teg yet. so far i haven't had a chance to do any brakes on a teg so i'm not 100% sure how well this would work on a teg. but works well on other cars. fast too.
Old Mar 15, 2003 | 06:31 PM
garados's Avatar
That's what I use. I don't know what the obsession with c clamps is. I have used pliers for more things that I've used c clamps for. IMO, getting the adjustable pliers is a better investment.
A little off key: pliers looks funny if you read it enough times
Old Mar 15, 2003 | 08:01 PM
Community Builder
Default Re: Do i need a c-clamp for changing front break pads? (garados)
lol I do that sometimes, I'll end up saying it over and over again in my head "pliiiiiiiiierrrrrrrrsssssss"
Old Mar 15, 2003 | 08:08 PM
94TealGSR's Avatar
Default Re: Do i need a c-clamp for changing front break pads? (PatrickGSR94)
Adjustable wrench or "channel locks" work too, but I prefer the c-clamp. Whatever floats your boat...
As for the "pliiiiiiieeeeeeerrrrsss"... that's what m-w.com is for, to check spelling after you've weirded yourself out about a word.
Old Mar 15, 2003 | 08:19 PM
tC_Dragon's Avatar
I like to use the c clamp so that i can manuever it in such a way that it compresses the piston from the center of the piston, and not anywhere else.. so that it will compress more evenly. i worrie that if i do it on the lip or unevenly, that it might decompress unevenly and cause uneven pad wear. but it could be me jus be too picky.
Old Mar 15, 2003 | 08:45 PM
Rtzx9r's Avatar
GDD 1%
Used my fingers the last time, but usually some channel locks work great.
Old Mar 15, 2003 | 09:42 PM
Henry HA's Avatar
HAnda-Tech Member
huh??
I think he means when he put in "x2" the site wouldnt let him post because you cant have more then half the letters capital
kidcool1977
Nov 30, 2008 05:42 AM
ylfotevoli
Nov 5, 2006 12:13 PM
Catscan
Jun 12, 2006 09:38 AM
92vx6
Nov 13, 2004 10:40 AM
spencedogg
13
Jun 9, 2003 11:21 AM
