DIy camber kit?
Old Mar 15, 2003 | 11:30 AM
simplegreenmachine's Avatar
Default DIy camber kit?
does anyone know of a DIY camber kit
TIA
-Jason
Old Mar 15, 2003 | 11:42 AM
teal_dx's Avatar
Default Re: DIy camber kit? (ScrappyCiv)
i was wondering too, if the directions for 96-01 DIY rear camber correction will be the same for a 92-95 civic hatch?
Old Mar 15, 2003 | 11:57 AM
Default Re: DIy camber kit? (teal_dx)
i need 92-95
HENRY's Avatar
New User
The DIY camber kit only corrects rear camber. Look inside the wheel well and you'll see an small arm attached to a plate with two bolts that connect to the body of the car. Add a few (3-4) washers between the plate and the body of the car to add positive camber. I believe this is the same method for 92-00 Civics.
Old Mar 15, 2003 | 12:05 PM
teal_dx's Avatar
Default Re: DIy camber kit? (HENRY)
yes this is the same info i read for 96-01, but they only put 2 washers (maybe they had thicker washers?)
they also bought slightly longer bolts and used some kind of thread lock on them. I guess if your Civ is slammed then you would need more washers
jeison
Jun 9, 2006 12:16 PM
Mr_EmO
Suspension & Brakes
May 18, 2005 11:44 PM
fafsa
Apr 6, 2005 03:40 PM
drewbie
13
Jan 6, 2005 03:13 PM
deez nuts
14
Feb 3, 2003 11:16 AM
