honda ecu AND turbo/supercharger?
if i were to get the hondata ecu upgrade. wouldn't that do something in raising my compression ratio? because in the future i'd like to get a turbo or supercharger. but high compression = low boost right? so the question is. will the ecu upgrade raise my compression ratio?
the hondata reflash does nothing to change the comp ratio of the engine. to change you comp ratio of the engine youd need to physically go inside and change parts, ie: pistons. from what ive read the hondata is made for NA engines with a CAI or stock so i dont id work too well with a turbo or super charger.
Doug684
Dec 30, 2003 09:59 AM
gocivicgo
May 28, 2003 05:30 PM
harryg
Jun 20, 2002 07:56 PM
