Headlights on = radio static
Old Mar 15, 2003 | 04:50 AM
honda_joe's Avatar
Default Headlights on = radio static
In my 93 EX, whenever I turn on my headlights I get a small, yet annoying, amount of static in my speakers. Its really bad if I flip over to radio. Is this common for 92-95 civics? Anybody know of anything to check. It sounds to me like something isn't grounded properly or its not clean.
Any suggestions?
P.S. I did do a search so don't yell at me if this topic has been covered
Old Mar 15, 2003 | 09:53 AM
honda_joe's Avatar
Default Re: Headlights on = radio static (honda_joe)
I figured it out.
For those with the same problem, run a separate ground wire to your headunit. I ran the wire to a metal bracket right behind the ashtray/pocket/lighter piece. You can't miss it. Make sure you clean off the metal before you connect to make the best possible connection. Also try to make the wire as short as possible for the best results.
Old Mar 15, 2003 | 06:27 PM
chameleon's Avatar
hey i get it too when my rear defroster is on :-x
i see what you mean. i can just take the ground right off since i made a small harness ..ima try that.
curtie94
Mar 15, 2011 09:35 PM
99siRACER
Dec 2, 2010 11:34 AM
jordan_civic
Oct 15, 2007 03:03 PM
H.
Audio / Security / Video
Nov 1, 2004 06:20 PM
brian estrada
Jul 30, 2003 11:59 PM
