jdm 4-1 header
i have a 97 gsr with a aem cold air intake and an apexi ws exhaust...i am leaning on getting the jdm itr 4-1 exhaust...i know the power gains are in the high end but i was wondering will i lose power in the lower rpm's??...will my car be slower off the start then with my stock gsr headers??any info would help
You will lose torque and low end. Just launch high. You've already said it though. You will have increased power in the high RPM's.
LS/GS/RS = 4-2-1
ITR/GS-R = 4-1
I think these setups would be best for these cars IMO.
LS/GS/RS = 4-2-1
ITR/GS-R = 4-1
Should have thought about this before you bought your exhaust.
The Apex'i WS is a 60MM (2.36") OD exhaust
the 4-1- has a 2.5" OD collector
It won't mate up to your stock cat, which means you are going to need to get a 2.5" ID cat.
So you are going to end up making the exhaust smaller as you move away from the engine, which is bad for exhaust flow. If anything you want to get slightly larger the further away from the engine, to prevent exhaust reversion.
yes, it won't mate up to the stock cat which has a 1.8" inlet
You also need to swap your catback for a 2.5" version, otherwise you are seriously bottlenecking your exhaust system.
even though the ITR header has a 2.5 outlet, that's just the outer diameter, the inner diameter is actually only 2.125. The apexi WS has a 2.36" outer diameter, inner diameter is 2.1875. that's still bigger than the outlet of the itr header. IMO, a 2.25 cat would do fine for the job, although a 2.5 flows a little better. just my $.02.
i hope the owner of this pic (silverb18c1) doesn't mind me posting this, but i need to use it for reference.
outer diameter measurement:
after ghetto chopped, inner diameter measurement:
as far as flow goes, you will generally need 1 sq in exhaust cross section per every 60 whp you have. so if you do the math, unless you're planning to put down more than 225 whp, the apexi WS will be fine.
-demitri
edit: pictures
[Modified by SSBP DC2, 3:41 AM 3/16/2003]
-demitri
edit: pictures
Don't worry about the bottleneck, get a reducer.
So 225 hp to the crank, or 200 -> 210whp. If you only look at the piping. The WS has a chambered muffler, so that would be one thing to keep in mind in terms of flow.
Firestarter
Sep 5, 2005 08:11 AM
