B&M shifter vibration?
Old Mar 14, 2003 | 07:02 PM
Rwecked's Avatar
Default B&M shifter vibration?
How's everyone doing? I recently installed a set of ES shifter bushings and a B&M shifter. At upper RPMs the shfter seems to be rattling off the bolt to the linkages. I removed the plastic sleeve off of either side of the original rod and reinstalled it with new o-rings. Was i supposed to put the plastic back on or did I use the wrong diameter o-rings? It doesn't feel like the noise is heat shield related. Aside from the annoying rattle over 4000 RPM or so the unit works well and the feel is solid. Anyone else have this experience? Thanks and hope to see some of you this summer!
Old Mar 14, 2003 | 07:25 PM
HiRevn's Avatar
Default Re: B&M shifter vibration? (Rwecked)
My B&M rattles too.
Old Mar 14, 2003 | 09:12 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
That plus the straight non-bent design are the 2 reasons why I dislike B&M shifters. My $40 generic shifter has been great for over 1.5 years now, but I would love to have a Skunk2.
Old Mar 14, 2003 | 09:42 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Mine rattles at a certain rpm too but I'm so use to it I hardly notice it anymore. In fact I hardly ever remember that I have a B&M shifter.
Old Mar 14, 2003 | 11:21 PM
RICHJ's Avatar
My B&M vibrates also, I have already fixed it once when I found that one of the nice orange silicone "bushes" had split. As the motor is getting taken out I'm going to try again and see if I can make something a little more permanent with some poly bushes or metal inserts.
[Modified by RICHJ, 8:23 AM 3/15/2003]
Old Mar 15, 2003 | 04:40 AM
Rwecked's Avatar
Default Re: B&M shifter vibration? (RICHJ)
What I am gathering is that this is the way it is. Anyone manage to find a solution before I get back underneath her? I am thinking of installing a poly sleeve around the through bolt to keep it quiet (I'll check the orange bushings as well). I'll keep you posted.
Old Mar 15, 2003 | 07:45 AM
Rhino's Avatar
Replace the orange o-rings on the shift collar with some that are slightly larger. You will need to grease them really well to fit the collar back in. Put only one large o-ring on one end of the collar and put the other (3 I think) ones all on the other end. It won't completely go away, but the rattle will be greatly reduced.
Old Mar 15, 2003 | 11:41 AM
Rwecked's Avatar
Default Re: B&M shifter vibration? (Rhino)
Are we talking the plastic collar that comes off the through bolt? Also, 3 on driver's side or passenger side? Thanks for the help.
Old Mar 15, 2003 | 12:08 PM
itr98's Avatar
Hi Guys.....my b&m rattles too.i think that is the nature of the beast...Love everything else about though.
Old Mar 15, 2003 | 05:34 PM
ejprimo's Avatar
Default Re: B&M shifter vibration? (tubelor)
my B&M shifter rattled too.
Old Mar 15, 2003 | 05:40 PM
euclid's Avatar
Default Re: B&M shifter vibration? (ejprimo)
Old Mar 16, 2003 | 05:54 AM
Rhino's Avatar
Are we talking the plastic collar that comes off the through bolt? Also, 3 on driver's side or passenger side?.
Sorry, not the plastic collars, but the gold piece with the 4 grooves in it. Replace the 4 small orange B&M o-rings with slightly larger ones. If I remember correctly, put 3 large o-rings on the driver side and one on the passenger. This will give the shifter a slight lean towards the driver's side.
By moving the gold piece this far in the shifter, you will be centering the 2 smaller o-rings in the hole on the bottom of the shifter and reducing metal to metal contact.
[Modified by Rhino, 9:55 AM 3/16/2003]
Old Mar 16, 2003 | 01:11 PM
s2k420's Avatar
Yep mine to
Old Mar 16, 2003 | 11:11 PM
dax-es's Avatar
Or you could just get a section pressed in to do away with the o-rings altogether and get rid of the buzzing. You could also put a bend in the shifter so you can put a cup in the holder and not worry about hitting it.
Delano5050
10
Feb 25, 2008 03:27 PM
slash00R
Nov 1, 2004 07:23 PM
Undercover_Skank
Sep 20, 2004 06:20 PM
BringIT
Oct 25, 2002 09:28 PM
