NeeD help ASAP, just did an ek swap with itr motor and car don't start....
Old Mar 14, 2003 | 05:11 PM
powerfulperformance's Avatar
Default NeeD help ASAP, just did an ek swap with itr motor and car don't start....
I need help from you guy really fast. I just finish installing a itr engine inside of a 96 ek. I am using the obd1 conversion harness with a custom program. I have toda c with 440 injectors, which the custom yoshi program can control. I ran the vtec line, vtec pressure and the knock sensor. I don't know if i am doing something wrong, but this **** wont start up. The engine rotates, but wont start for nothing. Any suggestion on what the problem maybe. I am using a si distributor, does this make a difference.
ExospeedAMcrx's Avatar
Default Re: NeeD help ASAP, just did an ek swap with itr motor and car don't start.... (powerfulperformance)
where there any codes?
Old Mar 14, 2003 | 05:13 PM
Default Re: NeeD help ASAP, just did an ek swap with itr motor and car don't start.... (exospeedAMcrx)
when i put the keys in the on position, no codes.
Old Mar 14, 2003 | 05:40 PM
Jawad.'s Avatar
you should try the hybrid forum
a1320addict
Oct 11, 2012 11:28 PM
NOTDISFA5
Sep 5, 2010 06:03 AM
rwlangdale
Jan 7, 2008 07:39 PM
hatchbkdrvr
Dec 19, 2007 05:40 AM
