Lots of stock crx parts and b16a parts etc.
Make offers
FS: Brand new obd1 B series vtec distributor, Pm me for details
FS: autometer oil pressure electrical sender unit only no gauge
FS: Pair of sprint springs front only, cut still stiff with nice drop
FS: ZC oil cooler
FS: 88-91 crx si rear mud flaps
FS: 88-91 JDM crx fuse box inside of engine bay
FS: 88-91 crx starter from autozone low mileage
FS: 88 crx si motor mounts and brackets
FS: 88-91 crx si upper and lower heat shield
FS: 88 crx si intake arm and intake box stock
FS: 88 crx si front suspension fork
FS: 88 crx si passenger and driver window crank handles
FS: 88 crx si big metal ecu cover
FS: 88-91 crx stock d series header upper portion 4-2-1
FS: 88 crx front and rear bumper
FS: 88 crx si cluster cover
FS: 88 crx si defrost button
FS: 90-91 crx si cluster cover
FS: 88 crx hf gauge cluster parting out temp and gas gauge
FS: 88 crx si dimmer switch
FS: 88 crx rear speaker mount bracket
FS: 88 crx si passenger and driver interior pillars
FS: 88 crx si dome light
FS: 88 crx AC system parts and various AC hoses
FS: 88 crx fuse panel cover inside of car
FS: 88 crx driver and passenger sun visors
FS: window wiper motor system
FS: rear crx hatch with and without broken glass ebrake assembly
FS: 88 crx main relay
FS: 88 crx si upper timing belt cover
FS: 88 crx center console
FS: 88 crx si blower the one under the dash
FS: 88 crx si driver side engine bracket timing belt side
FS: 88 crx rear tranny bracket
FS: 88 crx rear view mirror
FS: 88 crx si front calipers
FS: 2 88 crx si fuel rails
FS: 88 crx si clock
FS: 88 crx rear hatch no wiper
FS: 88 crx si map sensor and two other tiny canisters sensors related to smog
*Inquire on any other stock crx part*
FS: b16a oil cooler *sold*
FS: 88-91 JDM crx b16a intake tube *sold*
FS: b16a valve not in mint condition
FS: 1 b16a AC compressor
FS: 1 b16a AC mount
FS: b16a crankshaft
FS: 1g b16a vtec solenoid bottom portion only
FS: 4 1g b16a injectors
FS: 4 b16a pr3 pistons $75.00 *sold*
FS: 4 b16a rods
FS: b16a throttle body minus tps sensor
FS: b16a engine block water coolant pipe and peice that holds the thermostat
FS: b16a intake and exhaust cams with gears
FS: b16a main bearing caps with bolts
FS: 1g b16a intake manifold complete with injectors, fuel rail, minus throttle body
FS: 1g b16a downpipe and upper portion of header
FS: b16a used water pump
FS: 1g b16a fuel rail
FS: 95 GSR fuel pressure regulator
FS: 86-89 integra ZC oil pan
FS: 86-87 integra ZC valve says HONDA on it in big letters painted blue
FS: 90-93 integra rear trailing disk brake and ebrake cables *sold*
FS: 90-93 rear teg lCA
FS: 95 LS intake manifold bare *sold*
FS: 95 LS driver side engine bracket timing belt side
FS: 95 Ls alternator brackets
FS: 94+GSR upper engine mount driver side
FS: 95 Ls head complete *sold*
FS: new exedy stock clutch disc for the 94+ integra
PM me with any questions or email me at johny5w64@aol.com
FS: JDM vision corners for 92-95 civic real deal authentic brand new *sold*
FS: 88 crx si ecu pm6 *sold*
FS: 88 crx glove box black *sold*
FS: 88 crx si front upper control arms *sold*
FS: 88 crx si front sway bar *sold*
FS: 88 crx climate control small crack *sold*
FS: 88 crx headliner *sold*
FS: 88 crx si steering rack *sold*
FS: DOHC upper ZC timing belt cover *sold*
FS: single ZC motor runs great minus distributor and flywheel *sold*
FS: 88 crx si rear cargo cover is in two pieces *sold*
FS: 88 crx si storage compartment *sold*
FS: 88 crx front suspension hub assembly *sold*
FS: 88 crx si dash *sold*
FS: Sunroof rails and assembly *sold*
FS: 88 crx injector resistor box *sold*
FS: 88-91 crx radiator support *sold*
FS: 88 crx rear cargo cover in two peices and storage compartment *sold*
FS: 88 crx stereo holder/ashtray/cigarette lighter plastic piece *sold*
FS: 88 crx rear tail lights good shape with crx sticker*sold*
FS: 88-91 crx shiflinkage *sold*
FS: 88 crx si passenger seat $90.00 *sold*
FS: 88 crx Driver and passenger window *sold*
Fs: 88 crx driver and passenger window regulator *sold*
FS: 88 crx si complete clutch, brake, gas assembly perfect for auto to 5 speed includes all bolts *sold*
FS: 88 crx si sunroof control botton *sold*
FS: fuse box in the engine bay *sold*
FS: JDM SiR 88-89 crx corner lenses $75.00 *sold*
FS: 88 crx shell front end damge pm me for more details *sold*
[Modified by JohnnyEF, 1:03 AM 4/1/2003]
[Modified by JohnnyEF, 1:27 AM 4/9/2003]
Modified by JohnnyEF at 2:43 PM 4/10/2003
Modified by JohnnyEF at 2:07 PM 4/23/2003
Modified by JohnnyEF at 10:48 PM 4/29/2003
FS: ZC oil cooler
FS: 88 crx si clock
FS: 1 b16a AC mount
FS: b16a crankshaft
FS: 4 b16a rods
how much for the front fastbrake kit.
what year throttle is the b16a off of? does it have a map sensor?
How much for the CRX Si intake manifold and ecu shipped to 30533. I already have an injector resistor box.
b16a1 transmision/clutch? Have it for sell?
Hey man, is the brake kit still for sale? I am interested! Thanks! Rick
Yes the kit is still for sale, check your pm
You wouldn't happen to have the driver side door panel from the 88 CRX Si do you? Please email me if you do. Thanks.
[Modified by Denny317, 6:57 PM 3/19/2003]
sold already
sold already
