RS*R spring problems ..
Old Mar 14, 2003 | 01:35 PM
JdMCiviCCupE's Avatar
Default RS*R spring problems ..
This is really directed at civic owners but anyone can answer... i have a 95 coupe and i just installed the 2" RS*R springs .. my drop is unequal ..the front ended up getting slammed ..looks like 2.5 ..tires tucked ..even rubs sometimes .. the rear has like an inch of wheelwell space.. and ontop of that ..i heard the suspension is great ..i used to have H&R ..my only problem was it wasnt low enough ..(1.8 and 1.6) .. these RS*R's are muchhh bouncier...anyone expirience this?
Old Mar 14, 2003 | 01:41 PM
WAFFLES's Avatar
Default Re: RS*R spring problems .. (JdMCiviCCupE)
yeah that's about the amount of drop to expect. 2.5"f 2"r
Old Mar 14, 2003 | 01:44 PM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
Default Re: RS*R spring problems .. (WAFFLES)
are you sure you didnt mix up the rear for the front?
Old Mar 14, 2003 | 01:46 PM
dwnthehatch's Avatar
Default Re: RS*R spring problems .. (CiRcUiTsi)
I had the same problem with my rsr down springs.
Old Mar 14, 2003 | 02:39 PM
RSZero1's Avatar
Default Re: RS*R spring problems .. (dwnthehatch)
you have them installed wrong, fronts are in rear and vice versa...trust me, that will fix it
Old Mar 14, 2003 | 03:42 PM
Default Re: RS*R spring problems .. (RSZero1)
no they are not installed wrong anmd my man who put them in just read this and got mad and was like i do this everyday...how they gunna say i put them in wrong
Old Mar 14, 2003 | 03:46 PM
jus f0 dekarayshunZ
people make mistakes...i didnt mean anything by it
Old Mar 14, 2003 | 03:47 PM
andrew dc's Avatar
from my expierence with rsr springs, in only twice, they left an even 1 finger gap all the way around.... kinda looked weird at first rather then the tucked up front and higher in the back deal I am used to seeing.
Old Mar 14, 2003 | 03:49 PM
EGsixer's Avatar
if he does it everyday then why are you askin us? go ask him.
Old Mar 14, 2003 | 03:55 PM
dwilson's Avatar
Old Mar 15, 2003 | 03:55 PM
SpoonEK2's Avatar
Default Re: RS*R spring problems .. (dwilson)
My RSR down springs dropped my car 2" in the front and 1.2" in the rear...
From the specs on the springs, this is the correct drop. Did you get the blue or black springs?
Old Mar 15, 2003 | 06:33 PM
Default Re: RS*R spring problems .. (SpoonEK2)
i have the blue .. i think im going to get rid of these springs ..the ride is sooo bouncy compared to my h&Rs
Old Mar 15, 2003 | 06:39 PM
eg6sir-s's Avatar
i have gone to two sets of rs*r blue(down springs) and no problem...are your shocks blown? did you cut the bump stops in half? or put them back at all? did you line up the springs with the pirches and base of the shock?
btw with 195/50/15 i have 1/2 finger gap on all four wheels.
[Modified by eg6si, 8:02 PM 3/15/2003]
Alex Nico.JDM
Suspension & Brakes
12
Oct 29, 2012 06:47 PM
J4k3
Jun 12, 2007 07:15 AM
Ragnaarok
16
Apr 21, 2007 09:00 AM
Timmy!
Suspension & Brakes
Apr 19, 2006 07:23 AM
lazyxazianxboi
Oct 26, 2004 12:34 PM
