d series crank help ??
Old Mar 14, 2003 | 05:57 AM
spun Vtec's Avatar
Default d series crank help ??
I got a call from the machine shop today they said that my crank from the d16a6 is too far worn to use i have a d16a6 crank and i was wondering if it would work i dont really see why not but im giveing it a shot. Will this work??
thanks
what cranks are diff as far as d series?
Old Mar 14, 2003 | 06:46 AM
Louie B.'s Avatar
Default Re: d series crank help ?? (4gsicivichatch)
I'm assuming you meant to say that your spare crank is something other than an A6.... I would stick with an A6 crank personally, I know the A6 has a slightly higher volume than the other "1.6's"
Old Mar 14, 2003 | 07:46 AM
keithv's Avatar
Default Re: d series crank help ?? (thumpu77)
did you mean the z6 crank is too worn and you want to use the a6 crank?
you can always ask the machine shop to spec both cranks to see if there is a difference.
Old Mar 14, 2003 | 11:51 PM
spun Vtec's Avatar
I got a call from the machine shop today they said that my crank from the d16z6 is too far worn to use i have a d16a6 crank and i was wondering if it would work i dont really see why not but im giveing it a shot. Will this work??
thanks
thats what i ment to say sorry.. thnks
this is going in a d16z6 with a1 pistons y8 headgasket and peened z6 rods
[Modified by 4gsicivichatch, 3:53 AM 3/15/2003]
Old Mar 18, 2003 | 08:58 PM
spun Vtec's Avatar
bump
Evs-One
Feb 21, 2003 03:48 AM
Iceycrx
Dec 7, 2002 05:48 PM
