GSR springs on 92 CX?
Title says it all, I have a 92 CX with over 200k on it and i'm installing some koni reds, can i use the stock springs from a 98 GSR with them? I would assume so because the suspension is the same, but was wondering if anyone could confirm this. Also, if anyone knows, are the GSR springs stiffer than the civic ones?
Thanks
Tim
Thanks
Tim
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
yes, you can use gsr springs. but, personally (since you posted this forum) you should get some stiffer springs. frankly, the gsr springs barely have enough rate to keep the car up....
teggything
Aug 27, 2011 06:59 PM
