How do I get more power with a V-AFC???
Old Mar 13, 2003 | 07:13 PM
dseriessol's Avatar
Default How do I get more power with a V-AFC???
Can anyone give me good fuel curve settings for wide open with there v-afc to get more power, I'm rinnin a little ritch right now with a tail andinjectors I just want more power and want to program it right. Any help would be great, thanks.
Old Mar 13, 2003 | 07:28 PM
jdmCHEF's Avatar
Default Re: How do I get more power with a V-AFC??? (dseriessol)
first off, what motor u got?? what is done to it?? what are ur settings??? more info would help.
Old Mar 13, 2003 | 07:33 PM
sleeprhatch's Avatar
go get your car dynoed and tuned
Old Mar 13, 2003 | 07:34 PM
Kamin's Avatar
Default Re: How do I get more power with a V-AFC??? (sleeprhatch)
you cant just play with a vafc and make power
you need to have it tuned, or if your compotent and have a wideband o2 sensor and data logger. you can tune it yourself.
Old Mar 13, 2003 | 07:35 PM
dseriessol2's Avatar
Default Re: How do I get more power with a V-AFC??? (jdmCHEF)
d16z6, aem fuel rail, venom injectors, holly adjustable fuel pressure regular, denso iridium spark plugs, MSD wires, holly header, greddy SP cat-back, and I think thats all.
Old Mar 13, 2003 | 07:44 PM
DA MUGEN 1's Avatar
Default Re: How do I get more power with a V-AFC??? (dseriessol2)
First off to make more power let me just make some other suggestions! Ditch the venom injectors and switch them back to stock you car doesn't have enough upgrades to have injectors! I would also go back to stock wires and stock NGK plugs thats just personal preference though! Also I personally don't like AFC's but the only way your going to make power out of it is to get your car on a dyno otherwise you can cause serious damage to your motor if you don't know what you are doing
Old Mar 13, 2003 | 07:56 PM
Default Re: How do I get more power with a V-AFC??? (DA MUGEN 1)
I got a little project I'm workin on now that I will need the injectors and I love my densos, thanks for your help though, and does anyone know how to get the licence plate holder thing on the back of the sols off
Old Mar 13, 2003 | 09:27 PM
TurboBumblBee's Avatar
NEWBE!! please leave this forum.. your SOHC is slow and you dont know what you are doing..
Old Mar 13, 2003 | 09:31 PM
hybrider's Avatar
Default Re: How do I get more power with a V-AFC??? (Hybrid95CivicEX)
stfu
Old Mar 13, 2003 | 09:40 PM
DA MUGEN 1's Avatar
Dont take this the wrong way or anything because Im not trying to clown on you or anything but this is what your 4th post or so on this sight so your still kind of new here so let me tell you this you will run into alot of intelligent people on this sight who know halfway what they are talking about now let me tell you what you did wrong on this post so you learn from this experience so you don't get clowned on in the future!
1.You said you were running to rich (Dont you think you should take my advice that you don't need upgraded injectors right now use them later for the project that you say you have in the future BUT NOT NOW)
2.Everyone posted that you need to tune you V-AFC on a dyno for it to properly work for you you totally are ignoring what we are telling you because we are not telling you what you want to hear and then you change the subject in the end to how do you get your license plate thing off
Trust me take your car to a Dyno if you want with all the parts on your car that you have on there now and see how much power it produces. Then take my advice and go back to the dyno and see what the differences are then come back and talk to us! You asked for advice we are just trying to give you friendly advice so why not take it
[Modified by DA MUGEN 1, 10:44 PM 3/13/2003]
Old Mar 14, 2003 | 05:12 AM
Noe Kozz's Avatar
You need to hit the dyno first to notice any changes. I personally don't see the reason as to why you have bigger injectors, probably one of the reasons why you're running rich. Have the car tuned, then see what you get with the vafc. You can't just program it to give you more HP#'s. Good luck.
Old Mar 14, 2003 | 06:10 AM
B18C5-EH2's Avatar
Former Moderator
Loved
No matter what anyone says you need to go to a dyno and have it tuned with a wideband 02 sensor hooked up - PERIOD.
Add a fuel pressure regulator so that you can add fuel across the board and then use the V-AFC to trim away fuel on the rich spots.
I gurantee that you're probably running way lean in some spots, while running rich in other rpm ranges.
Ill echo what the other guy was saying in that you NEED to ditch those shitty Venom injectors.
First of all Venom injectors suck. they have a much higher failure rate than the O.E Honda ones from what I've seen in over 8 years in this Honda thing, and you have no mods that warrnt such big injectors.
Secondly how can you love a spark plug?
Sorry to burst any bubbles, but I seriiusly doubt that those Denso plugs are making any more power than stock NGK ZFR5F11 plugs will.
Worst of all is this:
You're paying an ungodly amount for some spark plugs that you're just going to FOUL OUT because you're probably running way RICH in some spots of your rpm range.
Bottom line?
Swap the O.E Honda injectors back in until you NEED bigger ones, and once you need bigger ones get some RCs and not Venoms.
Swap in cheaper NGK plugs so that when you ruin them by running rich you only ruined $12.00 worth of plugs instead of those pricey-*** Iridiums.
Old Mar 14, 2003 | 03:20 PM
dseriessol's Avatar
Default Re: How do I get more power with a V-AFC??? (B18C5-EH2)
Thanks for everyones help it is only my second car and I'm trying to build it right I was just curious if people could tell me there settings so I could get around spending a couple hundred dollars for a couple hours on the dyno.
Old Mar 14, 2003 | 03:33 PM
dseriessol's Avatar
hey dick I just turned 18 and am working part time (still in school) so for what I got is damn good, and I thought the purpose of these for was to help people not rag on there engines, hell if you had a car as nice mine when you where 18 I would be surprised unless you turned to mommy for everything, and my dseries beat a WS6 last night (I was just as surprised) so you can kiss my *** and I think I will stay. If I could afford to build a B I would.
Old Mar 14, 2003 | 03:48 PM
UtahRockabilly's Avatar
Basically some of the sentiments already expressed are how a lot of people feel. No one here is under any obligation to even look at your question they are doing it to share the knowledge of a sport they love. The easiest way to get your question answered directly and to avoid problems is to come with every possible concievable bit of information you can think of that might pertain to your question and give us all something to go with and then if you happen to get flamed which is almost inevitable then ignore it and go the next post that actually helps you.
Old Mar 14, 2003 | 03:50 PM
Phaze2 Mike's Avatar
Was the Ws6 on? Cause im sure you can understand why your 16 second delsol doesnt stand a chance against a possible high 12, low 13 second car. In fact, im not going to justify you saying that with any more comments. Get to a dyno, and before you make "come-back" statements, look who you are responding to. Granted alot of HT members now very little and think they know alot, thus spreading misinformation, but a few of the guys know their **** to the T. The only thing ill partially agree with is your denso's, they did help my car in throttle responce and ease of starts. Anyway, dyno time kid.
Old Mar 14, 2003 | 03:58 PM
Blue-Civic-Hybrid's Avatar
Loved
BULL!!! No way in hell unless the WS6 was turned off and coasting down a hill...
Old Mar 14, 2003 | 03:59 PM
dseriessol's Avatar
Default Re: How do I get more power with a V-AFC??? (Nextekhatch)
it wasn't a full run it was just a short little race from light to light and he had a shitty launch and an auto, I'm the first to admit he would have killed me in the quarter but in my eyes a race is a race and I won.
viprcr1's Avatar
Default Re: How do I get more power with a V-AFC??? (UtahRockabilly)
man u are a ricer your d series with basically only those mods beat a ws6 and my hugo beat the space shuttle in a 1/4 mile drag race what a tard
Old Mar 14, 2003 | 04:06 PM
soopafly828's Avatar
WTF??? peeps try to give u advice and this is how you show gratitude
Most people in here know what they are talkin about....
and i'm also going to school fulltime and dont live at home either, i've paid for everything that is on car myself (inlcuding the car) - and dont act like ur car is the **** either - you just do not understand how nice some of the peoples car in here are
Old Mar 14, 2003 | 04:12 PM
Default Re: How do I get more power with a V-AFC??? (soopafly828)
I was not replying to everyone I that was aimed at one person, I am very glad to have people that actually help me reply I just don't see the point in replying to a question by saying your car sucks, thank you everyone who has helped I was just calling the one guy who trashed d's and told me to leave this forum a dick
Old Mar 14, 2003 | 04:35 PM
untitled's Avatar
Default Re: How do I get more power with a V-AFC??? (viprcr1)
i know dseriessol and he is good friend of mine. first of all, how are all you big FAGGETS going to judge a person's knowledge on how many posts they have. i havent been on h-t that long at all and i've seen complete FUCKTARDS with 3-4-600 posts making complete asses out of themselves just b/c they are on the computer all the time and dont actually experience the work. so you cant judge a person's knowledge on how many posts they have.i love h-t. there is so much info to be absorbed on this site it's ridiculous. and i hate to bring down the purpose of the site, which is to inform, and say this. So, me and alot of others users would agree to say:
<U>honda-tech haters.......**** OFF you are just a bunch of BITCHES that think you extend your ***** size by talking **** on a ****** computer.</U>
second of all, i personally think a ricer is someone who puts all kind of goofy *** stickers on their ride, gets an intake and a fart can, installs those fagety-*** srayer l.e.d.'s, and has chrome homeycaps. i dont think someone starting out their car that they've only had for about 6-7 months with some pretty respectable bolt-ons out of a part-time job is pretty good. c'mon seriously, greddy exhaust is definetly rice. a fart can is rice people. for all i know, you haters could have those big coffee can exhaust things bolted to you ride. we have the turbo-setup nearly done right now. we are working on all necessary charge piping and having a cutsom downpipe made. and he didnt just get a kit. we are piecing it together with 2g dsm parts. so apparently, since turbo plans are rice, take your ****** turbo setup apart so YOU arent rice.
and as for the ws6 goes. i was in the car. yes the ws-6 would wail on him. but the fact is we got a 1car launch on it. it was light to light and when it was time to slow down, we were ahead. put it this way, you could have the fastest car in the world but it wouldnt be **** with out a good driver and it would lose. you could the most power of anyone you know, but if have shitty 195 tires and all that power is not worth anything.
soopafly and everyone who actually helped out...thanx
hybrid95 for someone who has 1400 posts you acting like real ****** idiot.
i respect alot of people on this site and when i see over 1000 posts i;m like damn. but as for you, it only goes to show how much you do like your sport. if you actually did like it, you try and help everyone out. including d's. and i'll bet anything with the money youve spent on your god almighty b, i could of had a 10sec mustong by now. yer a ****** *** dood. and personnlay i dont give a FLYIN FOCK if you got 1400 posts. your a little fairy. if your around fort. wayne in sometime, hit me up. we'll run your little b into oblivion....faget.
peace.
Old Mar 14, 2003 | 04:45 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Whoa there buddy.
I mod this forum and I'm trying to help you, but if you want to cop an attitude and talk bullshit about beating a WS6 Trans Am (street racing is for fucktards) then this is the wrong message board for you.
Chill out or i'll ban you and your I.P adress.
We're here to help, but yes there will be some ***** around to **** you off, so grow thicker skin or you'll hate life on the internet.
Old Mar 14, 2003 | 04:47 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Welcome to 98% for that remark.
How do you know if his SOHC is slow or not?
What do you call slow?
Give the guy a break - if you cannot contribute anything to the topic at hand, then don't reply at all.
Old Mar 14, 2003 | 05:40 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: How do I get more power with a V-AFC??? (88crx91integra)
peace.
If you ever post bullshit like this in this forum again I will post your I.P adress for the hackers to **** you, and then I will delete your user name and autoban your I.P adress forever.
Do you understand that?
For now consider your 2% point reduction a blessing...
Last thing really quick:
It's ******, not "fagget" or "faget" or whatever, and seriously you might have some homophobic issues since you try and use that word a lot.
