(question) crx tranny gurus help.
Old Mar 13, 2003 | 06:44 PM
IamVtec's Avatar
Default (question) crx tranny gurus help.
Will 91 hf clutch,pressure plate,flywheel work on a Crx Si tranny say either for a 88-89 or 90-91? And the hf axles should work also correct (fit on the si tranny)? ANy help would be apprecited. THanks
Im swapping the HF tranny out for the Si tranny.
Old Mar 13, 2003 | 06:49 PM
jlicrx's Avatar
Default Re: (question) crx tranny gurus help. (Full Throttle EF)
no problem unless you have 88 tranny - you would need different clutch disc
Old Mar 13, 2003 | 07:48 PM
AbaZ's Avatar
yup, the 88 has a different spline count.
you will also have no problem with the stock HF axles if you use the SI Trans.
Jeff
Old Mar 14, 2003 | 12:00 PM
IamVtec's Avatar
thanks for the replys
koolme88
23
Oct 6, 2011 12:46 PM
airikkCRX
Apr 14, 2004 06:07 PM
Tex Blackwell
36
Jan 8, 2004 11:51 AM
messeduprex
May 24, 2003 09:57 AM
Nossy
Apr 10, 2002 10:33 PM
