Is there a # or letter that tells which upper front arm goes on which side on G2s?
Old Mar 13, 2003 | 05:58 PM
TegRun's Avatar
Default Is there a # or letter that tells which upper front arm goes on which side on G2s?
I think my upper front control arms might be switched from left to right and right to left on my G2, but I cant tell from the shape. I need to know if there is a # or letter that tells which arm goes on the right and which goes on the left. Thanks
Old Mar 13, 2003 | 06:06 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Is there a # or letter that tells which upper front arm goes on which side on G2s? (TegRun)
it should have an L or R stamped on there somewhere, do you not see anything like that?
Old Mar 13, 2003 | 06:32 PM
TegRun's Avatar
I havn't seen a letter, but my arms are very dirty and packed with grime. So, before I go scrubbing them simply looking for a letter that may or may not be there I would just like to know ahead of time, so that I don't waste my time. But I sure hope there is a letter or #!
[Modified by TegRun, 3:33 AM 3/14/2003]
Old Mar 13, 2003 | 08:10 PM
tC_Dragon's Avatar
ur talkin bout hte upper a arms of the front suspension rite?? let me check the ones i took off my g3 teg... hold up
Old Mar 13, 2003 | 08:12 PM
tC_Dragon's Avatar
Default Re: Is there a # or letter that tells which upper front arm goes on which side on G2s? (pdcdragon)
ok on mine it on the top side it has "SR-R" on one and "SR-L" on the other.
Old Mar 14, 2003 | 08:28 AM
TegRun's Avatar
Thank you, i will check mine.
Old Mar 14, 2003 | 01:20 PM
tC_Dragon's Avatar
no problem.. hope its similar for ur g2...
Jonathan_ED3
Jul 11, 2006 07:25 PM
thomst4R
Suspension & Brakes
Jul 17, 2005 06:20 PM
essex
10
May 23, 2005 09:41 AM
extracrunchie
Dec 20, 2004 09:47 AM
