Max tire width on 90-91 CRX Si wheels......
Hey guys,
I'm picking up a set of of Falken Azeni's in a month or so, and would I be able to do 195/60/14's? Will I rub at all, even with stock wheels? I have H&R Sport springs and Koni Red struts, if that helps.
Thanks!
Thanks!
i have 195's on crx alloys on 88hb sittin on sprints 2 1/2" no rubbing..195's are taller than 185 60's though so ur gearing is a lil taller with them
Well, considering I have 205/50/15's on a 2" drop and don't have and rubbing problems, you should be fine.
[Modified by SlowCivicDX, 7:56 PM 3/13/2003]
red civic,
You have the Azeni's as well? What do you think of them? I'll be using them for a couple of track days.
Thanks everyone!
[Modified by Dru-Si, 9:17 PM 3/13/2003]
Thanks everyone!
Actually fullmetaljacket they are not taller, they are wider. 195 is the width. Anyways I am running 195/60/14 dropped 3.5 inches on rx springs and there is no rub. You should be fine.
I recently got a great deal on some 88 CRX Si 'Teardrop' alloys. Are these the same width as the 90-91's ?
What would be the widest tire I could safely fit on them ? 195's as well ?
And for a 195, what height would perform better ? 65,60,50 ?
X2
X2
Here is a good web site if you want to find out what size tire to use to make sure that your speedo stays accurate. Plus it will show you the difference in tire sizes as well.
http://www.miata.net/garage/tirecalc.html
X2
X2
would it be possible to put 205's on CRX Si wheels?
I'm using 195/60R14s as well
[Modified by raene, 1:21 PM 3/14/2003]
