Rolled fender and/or no lining
I was wondering how many people have rolled fenders, no wheel well lining or both
if you have them rolled which technique did u use? bat? broom? fender roller, etc
I would really like to see a how to on rolled fenders because I did mine but it still rubs and I think I can still get some more roll out of it but not the way I did it.
I used a baseball bat to roll mine. Started with the thinnest part of the bat, and worked my way up carefully
It worked for me. My Azenis were rubbing all the time before I did it. Haven't rubbed since. I don't like doing it, but it was necessary.
I was retarded and ran 215/40/17's before I was aware of the civic rubbing problem, rub a dub dub, it was rubbing in front and back. Rolled the rear and it still rubbed, rolled the fronts and it rubbed, sold the $1100 rims for $650 and it didn't rub anymore. I should've kept the rims and bought coilovers, probably would've saved me the money I lost on the rims.
Geo Metro Type-R
JDM 3-1 Header
JDM Integra Type-R EMBLEM conversion
Bling Bling hubcaps
JDM 3-1 Header
Bling Bling hubcaps
Oh yea and just take the small end of the bat...put it up in that wheel well and start pushin awayyyyyyyy
So how does this fender rolling work?
I want to do it but I don't konw what way to bend the tab part. I'm guessing you just bend it up and out of the way.
This side is rusty
so do i just roll that part up?
[Modified by 92civicsi, 6:56 PM 3/13/2003]
This side is rusty
fender rolling tool.
[a friend of mine] heat gun and fender roller.
on a bimmer
using a bat or broom stick whatever, can **** up your fenders.
[Modified by Sucka Free, 10:17 PM 3/13/2003]
on a bimmer
what is the bnefit of rolled fenders?
I have 205 azenis on my car with a +40 offset rim and it rubs
I riased it up a little but it rubs under hard turning. Who has no fender lining? And what are the pro's and con's of no lining?
Pro's- Tire will have more room before it rubs the fender since there are no liner screws
con's- Dirt will get in to the wheel well, (however couldnt you just hose it out whenever you wash your car?)
Any others thanks alot!
My car used to rub bad, but I just removed the front lining and I was set. No more rubbing. I have pretty wide wheels too. You do get some dirt in the wheel well, but oh well. I have not seen any downsides to no lining yet. Just make sure you keep some lining down by the intake filter.
How Much does one of those fender rolling tools run?
yea seriously
yea seriously
somewhere over a thousand.
on vwvortex, someone ends up buying the tool, and renting it out for other people to use.
what the hell did you do beat it with the bat? lol I rolled mine with a bat just enough that it does not rub any more
P.S. rip off that rubber strip that causes the fender to rust
[Modified by sleeprhatch, 11:38 PM 3/13/2003]
yah i kinda did'nt konw what i was doing with the bat haha.
For those of you that did roll, what setup do you have? Is this only a problem for 16+ wheels and lowered? I plan on getting 15's and lowered, will this rub?
i have my friend that has his rear fender rolled with a bat and hes riding on some 17" 215 tires, it doesnt rub....that **** is dumped
00 civic coupe
00 civic coupe
