Using msd rpm activator as my v-tec controller. Wiring Help needed.
Old Mar 13, 2003 | 01:34 PM
Sirex's Avatar
Default Using msd rpm activator as my v-tec controller. Wiring Help needed.
Ima use the rpm activator as a temp solution. i have a 4700 and 4900 rpm pill for my sohc d16z6 motor. in my 1991 crx si.
how do i wire this thing up? i tried search nothing came up.
thnx
Old Mar 13, 2003 | 01:58 PM
keebler65's Avatar
Default Re: Using msd rpm activator as my v-tec controller. Wiring Help needed. (Sirex)
well you'll end up getting an ecu code for one (if you have a vtec ecu). i've heard you can hook up a resistor to replace the spool valve to fool the ecu. then its as easy as taking the output of your msd and hooking it up to the spool valve. you'll have to read the instructions to find out what it outputs. it most likely outputs a ground, in which case you'd have to hook one side of the spool up to +12v, and the other side to the msd unit. if it outputs +12v, then do the opposite.
Old Mar 13, 2003 | 02:41 PM
zCivic's Avatar
Default Re: Using msd rpm activator as my v-tec controller. Wiring Help needed. (keebler65)
Thank goodness for Mechanic_B's site http://www.geocities.com/motorcity/s...vtec_cont.html
Old Mar 13, 2003 | 02:58 PM
Sirex's Avatar
Default Re: Using msd rpm activator as my v-tec controller. Wiring Help needed. (zCivic)
i have a pm6 ecu not p28
Old Mar 13, 2003 | 03:01 PM
zCivic's Avatar
http://www.geocities.com/motorcity/s...tec_cont1.html this is for a PM6
[Modified by zCivic, 7:01 PM 3/13/2003]
re_X_si
Oct 30, 2007 10:14 PM
kamikazeCRX
May 27, 2004 01:32 PM
Charlie Moua
Oct 3, 2003 10:50 AM
td04civic
Aug 26, 2002 10:30 PM
