What's wrong with my brake?
Old Mar 13, 2003 | 12:37 PM
92SiB18C1's Avatar
Default What's wrong with my brake?
My car brakes fine and all. But at the stop light, the pedal will go down slowly until it pretty much touch the floor. If I brake hard one time, it'll stop but will come back later. I bleeded the line and everything. Is it the MC or the booster?
Old Mar 13, 2003 | 01:05 PM
92SiB18C1's Avatar
Default Re: What's wrong with my brake? (b18onboost)
ttt
Old Mar 13, 2003 | 02:26 PM
Draco's Avatar
Default Re: What's wrong with my brake? (92SiB18C1)
This has been happening to me. Does it happen all the time or only sometimes? When it sinks to the ground and you get off the brake does your idle go up? If so then I think its the brake booster, which is expensive as hell. For my 94 si it was close to 400 bucks at hondaautomotiveparts.com. Try looking at car-part.com, they may be able to hook you up. Hope this helps.
Old Mar 13, 2003 | 04:31 PM
92SiB18C1's Avatar
Default Re: What's wrong with my brake? (Draco)
It only happens some time. I've never notice the idle. I'll watch for it. Thanks
Old Mar 14, 2003 | 12:35 PM
92SiB18C1's Avatar
Ok, nothing changes at idle. So I'm guessing the MC. Anyone?
Old Mar 14, 2003 | 12:39 PM
Gr8Wyt3's Avatar
id say time for a brake up grade or at least a mc
ps sounds like the mc is not holding preasure
pss u could also have an air bubble in your brake lines try bleeding them again but thouroghly
[Modified by B18RCoupe, 9:40 PM 3/14/2003]
[Modified by B18RCoupe, 9:41 PM 3/14/2003]
Old Mar 14, 2003 | 12:41 PM
92SiB18C1's Avatar
Default Re: What's wrong with my brake? (B18RCoupe)
Well, I would like to know where the problem is before I can upgrade. I think I'll do the 91 civic MC like Tom said. $60 ain't that bad. Thanks
Old Mar 14, 2003 | 01:48 PM
dwnthehatch's Avatar
It's most likely the MC like stated a few posts up. I had the exact same problem until the brakes went out completely.
Old Mar 14, 2003 | 01:52 PM
WongFeihung's Avatar
Default Re: What's wrong with my brake? (dwnthehatch)
sounds like the master cylinder just like dwnthehatch said. check your master cylinder if its leaking break oil..and if it is, then you have to install a new one. not too hard.
Old Mar 14, 2003 | 01:54 PM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
Default Re: What's wrong with my brake? (WongFeihung)
im not really familiar with brakes...but have you tried rebleeding and in the correct order??i already noticed you said you bled it but isnt there a certain order you have to do it in?
Randysi
26
Jul 26, 2012 03:28 AM
boarding2008
Jul 4, 2010 12:08 PM
Scott (T.O.A)
Mar 26, 2008 08:22 PM
SwampThing
Sep 12, 2005 02:41 PM
