Header clearance with LS???
Old Mar 13, 2003 | 08:42 AM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default Header clearance with LS???
I just bought a Chikara header for my CRX w/an LS swap. It doesnt even come close to fitting. There is no way in hell that it will clear the fan closest to the drivers side. I wish that i could just take that fan off. Can i...i mean is it used for the Ais it something really important? I dont have Ac so i wouldnt care if i took it off if it was for that. I need this header on today...i cant drive my car until it gets on. What can i do? Thanks
By the way...im using the new gen billet HASport mounts.
Sean
[Modified by sCeRaXn, 5:42 PM 3/13/2003]
Old Mar 13, 2003 | 08:51 AM
Mr Furball's Avatar
Default Re: Header clearance with LS??? (sCeRaXn)
If you have 2 fans then you don't need one of them. If you are stating that you took out the AC then you don't need the fan. You should have cut all the pipeing back to the firewall so you have more room to play with. ( talking about the ac lines) The header should fit.
Old Mar 13, 2003 | 09:25 AM
sCeRaXn's Avatar
Default Re: Header clearance with LS??? (FURBALL B-16)
So i dont need the fan on the drivers side? Damn itll make things SOOOO much easier if that isnt there. What do i do with the wires that go to it? Thanks.
Sean
Old Mar 13, 2003 | 09:31 AM
Mr Furball's Avatar
Take the fan out and put the wires some other place then in the way. It's a plug so you can wrap it up and put to the side. I would keep the wires around just in case you put the old motor in or you sell the car and that would be another selling point, If you don't care about them then CUT em.
Wrap some tape around them and call it a day. Put header on and DrIve J00.
bluenc-87
Sep 27, 2014 07:41 AM
H2bekallmotor
May 3, 2013 06:28 AM
JesseCRX
43
Mar 28, 2007 04:53 AM
LoneStarCRX
Sep 22, 2004 05:22 PM
