4 point harness install
Just ordered Sparco 4 point clubman harness,any pics or tips on install? I dont have a roll cage(yet) and removing rear seat is not a problem.Thanks for all your help.
it sounds like you're thinking about getting a cage, i'd recommend doing so before doing much with a 4-point, it's the proper way to do it (in a rollover, you can't duck if you're in a harness, so there'd better be something hard above your head protecting you). That said, you can probbaly get some eyebolts from racer wholesale or OG racing or someplace that will fit into the stock belt mount points for the lapbelt, and make sure you mount the shoulder straps at no more than a 30 degree angle from straight back (i.e., not to the floor, this can snap your spine in an impact)...again, a rollbar makes this a cinch. Check my website for my harness install, many similarities to your 4-point i suspect.
Send it back. Order a proper SFI approved 5/6 point harness when you get a rollbar and/or cage, until then use OE seatbelts.
If you complain about cost, consider the cost and pain of a severe head/neck trauma.
