Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
cutting bumpstops on tein ra coilovers
Old Mar 13, 2003 | 07:10 AM
euclid's Avatar
Default cutting bumpstops on tein ra coilovers
i have tein ra's on my 94 civic that are technically for the itr. my car weighs considerably less than a 2500lb itr and i am having to lower the spring perches too much which i think is contributing to ride harshness... is it ok for me to cut the bumpstops in half or do i have to just raise the car up alittle more? thanks for any input.
Old Mar 13, 2003 | 07:29 AM
6ghatch's Avatar
Default Re: cutting bumpstops on tein ra coilovers (euclid)
I don't think cutting the bump stops will help with ride quality unless your car is slammed low and your riding on them. You've just got a monotube, 45mm piston, 14kg/mm front 10kg/mm rear sprung coilover meant for the track, not for a "comfortable ride".
[Modified by 6ghatch, 11:30 AM 3/13/2003]
Old Mar 13, 2003 | 08:09 AM
chrisonepointseven's Avatar
Default Re: cutting bumpstops on tein ra coilovers (6ghatch)
might want to pick up a set of springs and bilsteins if you are looking for that smooth comfy ride.
Old Mar 13, 2003 | 08:21 AM
MattD@Stoptech's Avatar
Are you or are you not hitting the bumpstops?
Old Mar 13, 2003 | 09:20 AM
euclid's Avatar
Default Re: cutting bumpstops on tein ra coilovers (El Pollo Diablo v3.5)
dont get me wrong i have been riding on these for over 6 months and i am not getting rid of them i am considering upgrading to zeal s6 b/c they are 3way adjustable but they dont have pillowballs.... the thing is i dont know whether im hitting my bumpstops or not, i am not slammed in my civic, the tires arnt tucked or anything, but its still got about a 2" drop from the skock 4x4 height. i figure b/c my car is a few hundred lbs lighter than the itr, an itr owner would be able to have the perches an inch or so higher, and get a inch more of shock travel as a result.
correct me if im wrong though. thanks for the help
[Modified by euclid, 2:22 PM 3/13/2003]
jrodc5
Dec 4, 2012 12:22 PM
JasinC19
Suspension & Brakes
15
Feb 28, 2012 07:46 PM
stock ek
Suspension & Brakes
Jan 8, 2007 02:26 PM
numbnuts22715
Suspension & Brakes
Dec 28, 2005 12:52 PM
CivicSimon
Jun 18, 2002 07:47 AM
