need help with ecu code 7 and 13
ok my crx zc keeps flashing a code 7 and has been for sometime now and i have checked the voltage on the tps and everything was correct and i just replaced the ecu today and i'm still getting a code 7 along with a code 13. I need and want this fixed asap so if any one have any info about this please post it up.
The TB is a JG big bore if that means anything about the TPS
also how do you fix a code 13 ie..where is the Atmosphric Pressure thing
i just posted yesterday the trouble shoot of a TPS sensor...
search for it... should be on page 2 or 3
and as for code 13.. thats all i can give u
yeah i saw that but i have tested the voltage at WOT and idle and it's 4.5 at wot and .5 at idle. I have also tested another ecu (the one that throws a code 13) and it still throws a code 7. I know if's not the TPS and the ECU is good so what could it be?? Also before it started throwing the code 7 i got my dizzy replaced and they had to rewire it so is there a possiblilty that they could have messed up some wires and that could be the reason for the tps code??
