How can I tell if I really need to replace my pipe-A?
Old Mar 13, 2003 | 05:05 AM
civic91's Avatar
Default How can I tell if I really need to replace my pipe-A?
Hello guys, could someone tell me how can I tell if I really need to replace my pipe-A? The dealer told me that the sounds that I'm hearing is probably my pipe-A. How much I'm expecting to put a new pipe-A, parts and labor? Thanks for any input.
Thanks again,
Female driver of 1995 GS-R (civic91)
Old Mar 13, 2003 | 05:24 AM
JimBlake's Avatar
Default Re: How can I tell if I really need to replace my pipe-A? (civic91)
The one on my '95 GS-R made a buzzing noise that sounded just like a loose heat shield. Drove me nuts 'cause I couldn't find anything loose.
The A-pipe is a pipe-inside-of-a-pipe. The inner pipe buzzes against the outside pipe. I don't know how to tell for sure until you take it off & look. Make sure its not just a rattling heat shield, tho...
That's a real expensive pipe ($400?). It was cheaper for me to buy a DC header. Don't know about labor, it took me a couple hours.
Old Mar 13, 2003 | 08:31 AM
Rory Breaker's Avatar
Default Re: How can I tell if I really need to replace my pipe-A? (JimBlake)
If you hear rattling on a 94-95 GSR from 3-4K RPMs, chances are its your a-pipe. Just get an aftermarket header or a used 96-99 header, that will solve it.
Old Mar 13, 2003 | 08:33 AM
94TealGSR's Avatar
I had the same problem untill I replaced my header. Rattling from 3-4k sucks.
Inaccurate
Feb 9, 2010 08:40 AM
96GeeSR
Feb 28, 2009 12:55 PM
Nushuktan Tulyiagby
Jun 8, 2006 09:57 PM
jonoknut
Jan 15, 2003 09:57 AM
Astro
Apr 18, 2002 09:58 AM
